Compression bit tips and tricks
you can just turn off your dust collection when doing your outline and if the shaving don’t cause your sled issue then you can just let it go with no tabs and the dust will likely hold your piece in place preventing any damage from tab process (use at your own risk to you and your workpiece) an a .125 inch comp bit runs good at 40 ipm feed 20 ipm plunge .25 in step down EANOSIC Extra Long 3 inch Spiral Router Bits Up Down Compression Bit 1/8 inch Cutting Diameter, 1/4 inch Shank Solid Carbide CNC End Mill with NACO Coating for Wood Carving Engraving Grinding - Amazon.com
I wouldn’t rely on this as a way around a good dust collection. Cutting through sawdust may cause your bit to dull quicker and even start a fire.
