Hello,
Has anyone used Maslow to cut correx or fluted plastic successfully? It would be 10mm thick and it is used for making Christmas lighting props. This is normally cut on a full-size CNC machine.
Hello,
@anna did a video about cutting that a few months ago
Awesome thank you. I guess some tweaking and bit testing to get a clean cut will be needed.
fewer flutes (single flute) with the router running as slow as you can, and
probably with the feed rate as fast as you can is probably the way to go
the problem was heat, which is from having the bit spinning against the plastic
too much.
Thank you. I guess I will be placing an order for a 4.1 ![]()
