Does G17 still need to be removed from Fusion 360 post processor?
Hi,
Has there been an update to the Maslow firmware that now allows it to read G17? If not we will remove it from the Fusion 360 post processor. The thread below is where this first came up.
Thanks,
Will
The G17 command tells the machine to cut in the XY plane which is the only plane that Maslow is designed to cut in so the command itself isn’t processed and you might see a warning message, but everything will work totally normally
