There is a community out there building campers and trailers out of foam covered by glue/paint and canvas (search for Poor Man’s Fiberglass for more info). The idea is that the new foam boards are rated to 25 psi or higher against compression, but will snap as they are bent because the outside of the curve stretches and develops a crack. but put a layer of glue/paint and canvas/window screen on it, and it’s suddenly FAR stronger. An inch or two of foam (2" 4x8 at home depot is ~$40/sheet) gives you R12 or better, which is better than most houses.
the right way to cut this sort of thing is with a hot wire, but a machine to do this on a 4x8 ft sheet is pretty difficult.
But if you took a traditional maslow, and used motors that have a through shaft so you could put a sprocket on both sides of the workpiece. you could then have the workpiece vertical with a light sled on each side to hold the hot wire and do CNC cutting of your pieces very easily.
The maslow even supports not having a motorized Z axis, so you could poke a hole through the foam and run the wire through each time it commands the Z to go down and start cutting, pulling it out when it’s done (so you don’t need to worry about making sure that the CAM program doesn’t cut through your parts on the way to the next cut)
I know that we’re all eager for the maslow 4, but this hit me as something easy to do with the old approach that’s unique to it, so I thought I’d throw out the idea and see what people come up with
Strangely I just read an article on a poor man’s teardrop foam/fiberglass trailer and thinking I should add it to the it’ll never actually happen to-do list. Routers cut foam like butter as long as the bits will reach and you can handle the tool width gap.
Back in the 80s we started building a Quickie Aircraft Company Q2 kit, hot wired boat dock styrofoam covered with fiberglass and epoxy and spent several years working on it. Like many, life (farm, children, job travel, couple moves, building an appropriate shop) intervened and it was never completed, although we still have all the parts stuffed in assorted outbuildings. Glass cloth over foam is pretty easy, as long as you don’t mind mixing, stippling, and squeegeeing. If it’s strong enough to fly around in a less weight constrained trailer shouldn’t be an issue.
PMF is far cheaper than fiberglass/epoxy, not as strong, but apparently strong enough .
routers will cut foam easily, but they make a HUGE mess and a large kerf. hot wire cutting would let you cut mating parts nested, then rotate and glue them.
I’m currently building one of those trailers though mine is hybrid with wood panelling inside and I’m using epoxy on the outside. The kerf on a hot wire cutter is small enough I probably wouldn’t bother disconnecting and connecting for nested parts. Just glue the transit cuts back together with weldbond or the glue of your choice before coating.
However M4 appears to have pretty good dust collection which should negate the hassles of cutting XPS with a router.
Also one could use the Maslow to cut kerfs for the curved roof panels. A little calculating and a tapered bit and you could end up with essentially perfect curves without any voids.
Our airplane parts were hot wire cut, with a shaky looking cutter made from a 2x4 drilled to hold electrical conduit (1/2 EMT?), powered with a transformer connected to a fan speed control plugged into a 120v outlet. They recommended a variac but they were rather expensive and it probably wasn’t any safer. I’m probably lucky to have survived that…
If we have a Maslow then for a few sheets of 1 1/2" extruded polystyrene the mess should be manageable, and way easier than digging out the 8’ long cutter and it’s questionable power system.
use canvas or window screen instead of glass fiber cloth
use thick latex paint or wood glue (tightbond II is commonly used, tightbond III
is listed as waterproof, but a new layer won’t stick to a dry layer, so II is
more commonly used)
My thoughts exactly. I was thinking of these kind of bits https://www.aliexpress.us/item/2251832632343682.html cutting many parallel partial depth slots for a curved roof like a Conostoga wagon. Or for round cornered camper furniture that breaks before the human body to preserve shins and such.
Cheap enough it could be a new kind of semi permanent interior construction method for access panels. Hide your batteries, wiring, LED lights, plumbing, emergency supplies, behind a foam panel glued in place. If you ever need to get in there, simply break foam (tool free).
Cut a new panel when you get home.
Maybe use a hot knife instead of a hot wire? With a hot knife you wouldn’t need a double sided object, just a jig to hold the hot knife. Something like this seems optimal, as it is a round “blade” so you don’t have to worry about cut direction.
my experience with those is that they are great for poking holes in things, but
as the heat comes from the handle and not from the wire itself, the area away
from the handle cools as you move through the material and soon you have a bent
wire
There is an old drafting table trick where you use pulleys to keep the parallel rule parallel. I think you could use something like that to keep a mirror Maslow on the back side of a foam sheet. I’ll sketch it up. Cutting foam cleanly sounds fun
Wow, I just did a forum search for “Hot knife” and this is the newest thread.
I was hoping to be able to use my Maslow to do some foam cutting at some point - I really thought maybe we’d have gotten further!
many people do use the maslow to cut foam, but use the rigid foam (the pink/blue
boards) rather than soft foam.
the trick I was talking about in this thread does not work with the newer maslow
4. There are some hot knives that heat from one end, but they don’t heat well
Not the drafting thing but I might try to make a mirror Maslow sled. This set up would be separate from the Maslow belts and motors. The Maslow would be stuck to the top sled and would provide the power and position. I am not sure about friction and actual weights. Will report back if I get it to work.
Muahahahahaha! IT WORKS!! at least the basic mirrored sled part. Very satisfying to move around the top sled and have the bottom one move with it. Will stick the robot on it tomorrow. Then add the cutting wire.
Proof of concept definitely works. Haven’t got the hot wire in yet but with 3.5kg weights and 9 feet of travel on the weight towers the maslow was able to move around the two sleds and has enough power to overcome the friction. I used roller bearings on the bottom sled. I used sliding door wheels as the pulleys because I had them. Only problem there was the ropes falling of at extreme angles. I added wire guides and it went better. I tied off the two ropes from the sled on each corner to one rope because I did not have enough pulleys around. I think I would ideally keep two the whole way. This set up is limited to about 3 by 6 feet of travel. I think you could get more with the same dimensions of frame and towers with some tweaking. This whole thing might be easier in a shed or garage but it is fun to have it freestanding. In this test I just had the maslow tied to the top sled but the extra mystery holes in the maslow sled would be perfect for screwing it down.
Sorry for the Necropost, I’d type this up but hadn’t hit “post”.
Also, by “foam” I was mainly looking for the rigid pink/blue foam. So I think we’re talking about different things - sorry!
I had another weird idea - you could stand the foam up vertically. The issue there is making the sled push down on the work.
I see a few people have done an experiment with an “air table” maslow. How about a “Vacuum table dual maslow?” You’d have a maslow on both sides, and one of them could be ‘pushed’ against the workpiece with a vacuum base plate attachment.
Just spitballing.
I really think the hot wire attachment would work if you went slow enough, and hey, I’ve got all day.
