Extending Belts further before calibration
Ok…So While I’m waiting on my new PCB board from the store…I want to ask a question concerning extending the belts on my machine.
Before I ran into my firmware upgrade snafu, I was in the process of trying to calibrate the machine and got the belts to extend, but they would only extend so far. Now, I have built the standard wooden frame exactly as the guide shows…I haven’t put the stud/ mount points in for the machine yet because I was unsure of belt length…I managed to get them, the belts, extended, roughly centered the machine on the frame, and the belts on a couple of the corners were a bit short and wouldn’t reach my expected mount point. I know there is more belt in the spool but couldn’t get them to extend further…How do I do that?
I would also note that the instructions/ frame diagram does NOT call out a mount point hole location…I assume this is on purpose because you can have a smaller frame…Mine is full size 4’x8’…
Thanks,
Chuck
with the newest firmware, you tell it how far to extend.
with older firmware, tell it you have a larger frame.
Go to Setup, then Config
