The firmware 0.67 release notes say there is no need to update the yaml file anymore. The fields that let you enter dimensions are not visible in fluidNC (afer update) though.
Also the yaml file (I’ve entered the numbers the “old fashioned” way) now has a confusing description. t describes distance from the anchor points but lets you define a grid. "
Define the distance from the anchor points to the corners of the calibration grid in mm
maslow_calibration_grid_width_mm_x: 2000
maslow_calibraiton_grid_height_mm_y: 1000"
Finally, the software guide still wants you to edit the yaml file.
This is confusing to me.
Should Ik, or should I not touch the yaml file anymore?
