This might be a silly question, but what is the process for updating the index.html.gz and the maslow.yaml files? I tried simply uploading the files in fluidNC using manage local files, but the system states that there is no free space. I also tried uploading the files as a firmware update, but that didn’t work as well.
Make sure your computer is not unpacking the gz file on download. Mine was and it gave me that error.
I also find that deleting the html and restarting gives a new upload page asking for the missing file. You might find that one more clear.
Thanks. That worked perfectly.
My process was the following:
delete index.html.gz from fluidNC local files, upload new index.html.gz
delete maslow.yaml from fluidNC local files, upload new maslow.yaml
Finally I restarted FluidNC
Downloaded the latest firmware and with the update I also uploaded the new yaml and index files since i learnt that is the best thing to do. But does this mean you have to run calibration again. Or, can I just fill in the old numbers in the web interface and save.
In general, what is the exact procedure for firmware updates?
I’m ok now but it might be useful to know anyway.
I’m also asking because I somehow managed to zero ALL the parameter data in the yaml file. After updating all files I checked the parameters in the interface and they defaulted. So I filled in my numbers and saved. After a soft restart all parameters were 0’s.
Absolutely you can put the numbers in. No need to re-calibrate.
I did this too! I think that there is a bug, but I haven’t managed to reproduce it. Are you able to make it happen reproducibly?
Ok, so i think i’m having a similar issue. I tried to update to the latest firmware, index.html, and maslow.yaml. It seems that my computer did something funky with index.html and possibly unpacked it as you mentioned. I now am able to connect to maslow but i get a screen of gibberish (attached) what are the steps to fix this? can i SSH into maslow and replace the index.html, or what needs to happen?
Do you have a windows computer? If so the easiest option is to just wipe everything back to factory settings by plugging in a USB cable and running full-install.bat which will give you a fresh install of everything
Thanks, I’ll try that.
