First time Maslow user here. I got mine set up and it worked just great with callibration and a test file or two. Now I’ve got a more complex file that I tried to run, and it stopped after six inches of cutting and won’t respond. No web page, no blinking blue light from the board, either. The other LED’s seem to be on, but the amber ones don’t blink anymore either.
running the “Full Install.bat” script with the board plugged in with a USB cable should reset everything to factory settings
Then I found this post that says I just have to download the full install.bat file and run it from my computer. That’s where I hit the wall. I don’t have any Windows machines here and my Mac laptop doesn’t want to run a .bat file. Any help here?
To fully reset everything to factory settings download the win64.zip folder from the releases page 1, and then unzip the folder.
Plug in Maslow so it has power and then connect a USB cord from Maslow to your computer.
Double click on the full_install.bat in the folder you downloaded and it will re-install everything on the machine back to exactly how it starts out. Hopefully that will get things back to how they were before.
I run mine on a PC, so I can’t say anything specifically to Apple, but do you need a full reset? If there’s no LEDs or any activity at all, that sounds less like a computer issue and more like a power issue, a board issue, or possibly both.
I know this may sound a bit dumb, but I would first double check your power cord. I had mine keep shutting down mid-cut whenever the M4 was trying to make some cuts far on the left. It turns out that my power cord was getting stuck on a nearby table and it was coming slightly disconnected in the middle of the cord where the cord goes into the converter brick causing the M4 to lose power and stop. If it’s definitely getting power, then you may have a faulty board.
After a discussion with Bar on the support thread, it appears that the circuit board simply failed in this case. Using the .bat files had no effect - the system reported that nothing was found on the serial port. A replacement circuit board fixed the problem and the tool is working again. I guess the take-away from this is the following:
Steady lights, no blinking means the board has significant problems
If you want to reset your M4 using the full-install.bat file, you gotta have a Windoze PC I found one for $150 on Amazon Prime Day…
If you run the full install file and get errors, the board is probably shot.
According to what I read on the Internet (so you know it must be true), Boot Camp doesn’t support Windows on Apple’s newer models (with Apple chips instead of Intel), so you’d have to go to Parallels. That costs about $100/year plus a $150 license for Windows. The PC was much cheaper!
Has anyone tried the Whisky WINE emulator? I, too, appear to have a board that doesn’t have software and I only have Macs. (I just swapped the board to move to the JST connectors. I ordered and received the board months ago but only had time to tackle the upgrade now. Bummed that after reassembling everything I am dead in the water). I’m not getting any new wifi network showing up, only one solid Green led, no sign the steppers energize.
I’m not a software engineer, but I worked with a lot of them as a product manager and analyst. I’m only guessing, but I’d say it’s a slightly educated guess: I looked into those .bat files and they all call a .exe file (esptool.exe). The scripts look like they’d be easy to port over to BASH (command line system for Mac OS), but the .exe file is a compiled executable and would have to be ported to run on Mac OS (.app) - that’s probably a large scale project that would require a lot of volunteer time from somebody to make. It would also create two branches of code that would have to be updated simultaneously. So I’m not holding out any hopes for install files that run on Macs Bar may be able to confirm or deny my guess.
Also, This link provides more detailed information on what the Wine emulator is: WineHQ - Wine Application Database It looks like it’s a bit of effort to install, but the web site says that you don’t need command-line skills to get it going. I’m going to skip any testing of this approach as I just broke down and bought a PC. If there are a number of people who express an interest in this approach, I might pitch in and do some testing later if needed. But given the minimal responses to this original post, I’m guessing the Maslow community is mostly Windoze users…
I haven’t dug into this yet, but I’m sure that the equivalent program exists to
flash an esp from a mac (or linux system). I would start looking at instructions
for running platformio and flashing the chip.
I am actually also Mac only. I have a super cheap windows computer that I use exclusively to run the build process.
I had a conversation with the folks over at FluidNC about this a while back and they say that the build process SHOULD work on Mac and generate a Mac installer, but when I tried it, it didn’t work for me so it’s a bit of a research project.
I would LOVE help with it if anyone has a chance to take a look at it. The file build-release.py is the one that we want to run on Mac
I’ve been trying to take advantage of the full 8mb flash, but running Ron’s pio commands wasn’t working for me, and it looks like the current utilization is pretty much at 100%. I just updated the posix install scripts in this PR and sh full-install.sh is running on my mwhatever Mac mini.
If you want to build on your system, you’ll need to update platformio = r"C:\Users\bar\.platformio\penv\Scripts\platformio.exe" and os.chdir(os.path.dirname(os.path.realpath(r"C:\Users\bar\Documents\GitHub\FluidNC\.pio"))) to point to what they need to point to. You’ll also need to be in a platformio terminal (platformio bug face in the sidebar, then quick access → new terminal), then you can run python build-release.py to generate windows and posix targets.
