Hello All,
I am very very new to the CNC world though i have been working with AutoCAD for close to 20 yrs. That said i "thought i would be prepared for the onslaught of issues that i have been having. Hahaha… ha… ha…
Any whay, so i have built my first frame, cut a new sled (that i still have yet to use), as well as from scratch draw and cut my first object (pat on back) in Fusion 360.
Now i am trying my hand at engraving.
Dun, DUn,DUN!!!
So i found an image that i liked, spline traced it, exported it as a DXF, then re-imported it, set my bit dims, selected geometry, and had the program create a cut path (with no errors that i can tell). yet when i try to run the post process to generate the g-code it fails, to post that is… i get a file “name.nc.failed” file and i cannot seem to find out what is going on… is there a common problem that would cause this to happen?
anyone that has used the engrave function on Fusion 360 successfully please help…
i was using the “maslowcnc post processor”
