i am surprised your metal gears were destroyed instead of the plastic gear. I thought the whole point of using the plastic gear was that it would self destruct first. basically acting as the weak link in the chain of gears.
I believe all the other gear box failures were with the plastic gear. the plastic gear is the first gear to rotate so it gets the direct power from the motor.
