Gradually getting toi the point of Ground COntrol running (upgraded Linux to Ubuntu 18…etc), but now have encountered the following issue: [INFO ] [Logger ] Record log in /home/jules-tb/.kivy/logs/kivy_19-03-16_2.txt
[INFO ] [Logger ] Record log in /home/whoareyou4/.kivy/logs/kivy_19-03-16_3.txt
[INFO ] [Kivy ] v1.10.1
[INFO ] [Python ] v2.7.15rc1 (default, Nov 12 2018, 14:31:15)
[GCC 7.3.0]
[INFO ] [Factory ] 194 symbols loaded
[INFO ] [Image ] Providers: img_tex, img_dds, img_sdl2, img_pil, img_gif (img_ffpyplayer ignored)
[INFO ] [Window ] Provider: sdl2([‘window_egl_rpi’] ignored)
[INFO ] [GL ] Using the “OpenGL” graphics system
[INFO ] [GL ] Backend used
[INFO ] [GL ] OpenGL version <3.1 Mesa 18.2.2>
[INFO ] [GL ] OpenGL vendor <X.Org>
[INFO ] [GL ] OpenGL renderer <AMD REDWOOD (DRM 2.50.0 / 4.15.0-46-generic, LLVM 7.0.0)>
[INFO ] [GL ] OpenGL parsed version: 3, 1
[INFO ] [GL ] Shading version <1.40>
[INFO ] [GL ] Texture max size <16384>
[INFO ] [GL ] Texture max units <16>
[INFO ] [Window ] auto add sdl2 input provider
[INFO ] [Window ] virtual keyboard not allowed, single mode, not docked
[INFO ] [Text ] Provider: sdl2
[INFO ] [Base ] Start application main loop
[INFO ] [GL ] NPOT texture support is available
[INFO ] [GL ] Unpack subimage support is available
This is my terminal output starting GC. The [INFO ] [Window ] Provider: sdl2([‘window_egl_rpi’] ignored) is the same, so was barking up the wrong tree. Any difference with your terminal that could give a lead?
cross-referencing each other without a final solution.
If i was in this corner, as a novice i would try in order:
dist-upgrade
removing and purging python and kivy and bringing them back by hand
if the 2 above do not work, bite in the sour apple and go for a different distro.
I’ve had run GC on kubuntu and lubuntu in the past and are now running it on ubuntu mate 18.04.2 LTS in the home office with Fake_Servo for debugging and Manjaro (Archlinux) in the workshop.
I have Ground Control running on two laptops. One running Ubuntu 16.04 LTS and the other running the newer Ubuntu 18.04 LTS.
I think In both cases getting Kivy and GC setup was just a matter of adding the Kivy PPA to my repository list and installing it with a few apt-get commands. See my bash_history below…
Are you running X11 desktop with gnome? I think some people reported issues with Ubuntu 17 when it defaulted to use wayland instead of X11. Only other think I can think of is you can can break things in python when adding modules with apt and pip together. Maybe its best to just pip for adding python modules, other than adding the kivy ppa.
