Ground Control thinks the origin is in the middle of the upper left quadrant instead of the center point. When I start the cut the red dot moves the the lower right corner of the model image. This model is designed to be cut in the upper left, but the origin should be at the center not in the middle of the upper left quadrant. When I upload gcode to cut in the upper right quadrant Ground control places the origin in the middle of the upper left quadrant.
I tried uploading a new version of Ground Control and reinstalling. It did not work. The dimensions of the models I cut are now off by about 2.5 inches top to bottom, but correct left to right. I don’t know if this is the same problem, but the model in Fusion 360 has the correct dimensions.
