We are assembling our frame and trying to get the hardware and software up in tandem.
I installed v1.23 firmware on the Arduino, and I am trying to run v1.23 Ground Control.
The PC is a Windows tablet running 32-bit Windows 10 Home on an Intel Atom Z2670 @ 1.8GHz.
The firmware installed ok, and I used the Arduino serial monitor to verify it is sending data back to the PC regularly.
When I start Ground Control I get a command prompt with a list of diagnostic startup information (which I found recorded in the .kivy directory log files). These include messages about Kivy, Python, OpenGL, Shader etc.
I get one Warning: 0:20: ‘function_call_constructor@vec4_vec4@0’ : used without being initialised
Then
Success.>
Then a couple more info messages.
The GUI starts, which is a full-screen window with a title bar. The window is mostly black, with a smaller white rectangle within it. That’s all I see.
Then Windows helpfully tells me ‘GroundControl.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.’
Spoiler: no solution is notified.
I downloaded the previous version v1.22, but I get the same error.
What to try next? Suggestions appreciated. Thanks.
Yes. Unfortunately Samsung and Microsoft have conspired* to make it impossible to put Linux on this tablet (otherwise I assuredly would have done it).
The reboot after the partial update finally happened. Ground Control still doesn’t work, but there are still more updates, so I’m eagerly anticipating the conclusion of that operation (10% downloaded already! And it’s still only afternoon!).
If it doesn’t work I’ll get another laptop or tablet and try it, although I would like to know why it’s not actually working. The Kivy logs tell me just what I wrote above. The Ground Control log is empty, so no clues there.
See if you can download a newer video driver from Intel.com
That’s about a 6 year old chip that giggle says supports OpenGL 2.0. I don’t recall what Kivy/Ground Control require but it shouldn’t be hard to search it on this forum
