Ground Control wil not work on Laptop
Is there another program that can be used in place of Ground Control to control Maslow CNC. My laptop will not support the Graphics of Maslow Ground Control.
What OS is on your laptop? What is it’s make & model of your laptop?
not yet[1], although we are getting fairly close to where any grbl compatible
software will work.
[1] well, it is possible after the machine is calibrated, but it’s a lot of
manual work, so it’s not practical yet.
My Toshiba, Widows10.2
Can you tell me what CPU & graphics card are on that laptop? I ay be able ti gind information on it. Also have you ever used Ubuntu Linux?
I can not load the ground control software because this computer dose not have the graphic drives and dose not support the driver v2 I need.
On Question 2 No.
Thank 4 ur help
try the following -
What version of Open GL is shown ?
https://support.esri.com/en/technical-article/000011375
What model Toshiba? It should be near the screen, or on a sticker on the bottom. Toshiba has made a whole lot of different models, with different processors and other innards
I had the same problem as this. I checked all my lap top Pcs, quite old as around 2010 and all my desk top Pcs as well. Then it turned out that you may need whatever it is, a lap top or a desk top, it should have powerful a graphic card, like for gaming or for HD movies. So one for business or office use would not have those.You need one of GeForce, Radeon or Nvidia, not like a card on the intel chip or something like that.
On the other hand, almost all Mac books has powerful ones. So I was going to buy one but I found a core 2 duo lap top with Radeon card, instead…It doesn’t cost much, from 60 to 100.
If you are having hp laptop then just downloading the latest firmware will help you a lot I guess. Simply visit hp customer assistant and do the needful.
