As the title states, I had multiple good calibrations in the vertical postion but after removing it from the wall and laying flat on the floor it will not calibrate. Updated firmware and index to 0.81 last night and after 2 attempts last night and 3 this morning I’m somewhat baffled. I changed spoil boards to ensure there is nothing for the machine to get stuck on while moving around. Config settings for size are exactly as they were when it was vertical. I literally just unscrewed it from the wall and layed it down flat.
Serial Messages
Index.html Version: 0.81
[MSG:INFO: FluidNC v0.80 (Maslow-Main-061f8600-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:Sublime2]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.4.56]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Top Right pulled tight with offset -0.011]
[MSG:INFO: Top Left pulled tight with offset -0.054]
[MSG:INFO: Bottom Left pulled tight with offset -0.118]
[MSG:INFO: Bottom Right pulled tight with offset -0.086]
[MSG:INFO: Center point deviation: TL: 0.151 TR: 0.184 BL: -3.016 BR: -4.798]
CLBM:[{bl:2145.06, br:2145.97, tr:2152.41, tl:2151.75},{bl:2081.23, br:2084.12, tr:2220.89, tl:2218.72},{bl:1871.47, br:2299.34, tr:2424.89, tl:2028.25},{bl:1941.66, br:2359.12, tr:2364.29, tl:1949.16},{bl:2020.33, br:2422.86, tr:2303.39, tl:1875.20},{bl:2215.95, br:2222.92, tr:2085.61, tl:2080.65},{bl:2421.47, br:2027.40, tr:1875.74, tl:2297.99},{bl:2359.98, br:1948.34, tr:1946.40, tl:2358.52},{bl:2299.15, br:1874.29, tr:2025.40, tl:2423.79},]
Computing… This may take several minutesFitness: 2.0990272 in 100
Fitness: 2.0990272 in 200
Fitness: 2.0990272 in 300
Fitness: 2.0990272 in 400
Fitness: 2.0990272 in 500
Fitness: 2.0990272 in 600
Fitness: 2.0990272 in 700
Fitness: 2.0990272 in 800
Fitness: 2.0990272 in 900
Fitness: 2.0990272 in 1000
Calibration complete
Calibration values:
Fitness: 2.0990270589776228
Maslow_tlX: 0.2
Maslow_tlY: 2391.0
Maslow_trX: 3569.0
Maslow_trY: 2393.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3572.0
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2145.06, br:2145.97, tr:2152.41, tl:2151.75},{bl:2081.23, br:2084.12, tr:2220.89, tl:2218.72},{bl:1871.47, br:2299.34, tr:2424.89, tl:2028.25},{bl:1941.66, br:2359.12, tr:2364.29, tl:1949.16},{bl:2020.33, br:2422.86, tr:2303.39, tl:1875.20},{bl:2215.95, br:2222.92, tr:2085.61, tl:2080.65},{bl:2421.47, br:2027.40, tr:1875.74, tl:2297.99},{bl:2359.98, br:1948.34, tr:1946.40, tl:2358.52},{bl:2299.15, br:1874.29, tr:2025.40, tl:2423.79},{bl:2243.65, br:1807.09, tr:2110.48, tl:2492.38},{bl:2019.81, br:2022.30, tr:2297.39, tl:2298.39},{bl:1802.80, br:2245.81, tr:2496.34, tl:2110.23},{bl:1595.40, br:2472.69, tr:2702.26, tl:1936.21},{bl:1674.63, br:2521.62, tr:2640.46, tl:1844.78},{bl:1755.29, br:2576.62, tr:2580.23, tl:1757.51},{bl:1843.95, br:2637.02, tr:2524.58, tl:1674.94},{bl:1934.48, br:2702.55, tr:2474.15, tl:1598.02},{bl:2108.67, br:2499.57, tr:2245.61, tl:1803.97},{bl:2298.21, br:2300.34, tr:2021.64, tl:2021.18},{bl:2496.22, br:2111.87, tr:1804.84, tl:2246.37},{bl:2701.85, br:1937.54, tr:1597.62, tl:2472.68},{bl:2638.75, br:1846.23, tr:1676.61, tl:2520.35},{bl:2578.47, br:1758.95, tr:1760.16, tl:2575.44},{bl:2522.93, br:1676.47, tr:1847.25, tl:2636.21},{bl:2472.50, br:1599.66, tr:1939.41, tl:2700.04},]
Computing… This may take several minutesFitness: 0.8149603 in 100
Fitness: 0.8149603 in 200
Fitness: 0.8149603 in 300
Fitness: 0.8149603 in 400
Fitness: 0.8149603 in 500
Fitness: 0.8149603 in 600
Fitness: 0.8149603 in 700
Fitness: 0.8149603 in 800
Fitness: 0.8149603 in 900
Fitness: 0.8149603 in 1000
Calibration values:
Fitness: 0.8149603244715634
Maslow_tlX: -0.1
Maslow_tlY: 2391.0
Maslow_trX: 3570.3
Maslow_trY: 2393.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3572.0
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2145.06, br:2145.97, tr:2152.41, tl:2151.75},{bl:2081.23, br:2084.12, tr:2220.89, tl:2218.72},{bl:1871.47, br:2299.34, tr:2424.89, tl:2028.25},{bl:1941.66, br:2359.12, tr:2364.29, tl:1949.16},{bl:2020.33, br:2422.86, tr:2303.39, tl:1875.20},{bl:2215.95, br:2222.92, tr:2085.61, tl:2080.65},{bl:2421.47, br:2027.40, tr:1875.74, tl:2297.99},{bl:2359.98, br:1948.34, tr:1946.40, tl:2358.52},{bl:2299.15, br:1874.29, tr:2025.40, tl:2423.79},{bl:2243.65, br:1807.09, tr:2110.48, tl:2492.38},{bl:2019.81, br:2022.30, tr:2297.39, tl:2298.39},{bl:1802.80, br:2245.81, tr:2496.34, tl:2110.23},{bl:1595.40, br:2472.69, tr:2702.26, tl:1936.21},{bl:1674.63, br:2521.62, tr:2640.46, tl:1844.78},{bl:1755.29, br:2576.62, tr:2580.23, tl:1757.51},{bl:1843.95, br:2637.02, tr:2524.58, tl:1674.94},{bl:1934.48, br:2702.55, tr:2474.15, tl:1598.02},{bl:2108.67, br:2499.57, tr:2245.61, tl:1803.97},{bl:2298.21, br:2300.34, tr:2021.64, tl:2021.18},{bl:2496.22, br:2111.87, tr:1804.84, tl:2246.37},{bl:2701.85, br:1937.54, tr:1597.62, tl:2472.68},{bl:2638.75, br:1846.23, tr:1676.61, tl:2520.35},{bl:2578.47, br:1758.95, tr:1760.16, tl:2575.44},{bl:2522.93, br:1676.47, tr:1847.25, tl:2636.21},{bl:2472.50, br:1599.66, tr:1939.41, tl:2700.04},{bl:2427.55, br:1529.19, tr:2030.22, tl:2769.25},{bl:2193.99, br:1745.07, tr:2197.76, tl:2572.01},{bl:1964.46, br:1969.02, tr:2378.08, tl:2379.18},{bl:1740.48, br:2197.57, tr:2571.28, tl:2197.89},{bl:1524.72, br:2428.29, tr:2772.86, tl:2031.28},{bl:1320.94, br:2662.55, tr:2980.96, tl:1883.27},{bl:1401.18, br:2703.31, tr:2920.60, tl:1780.40},{bl:1488.76, br:2748.38, tr:2860.69, tl:1680.56},{bl:1582.68, br:2798.42, tr:2805.08, tl:1584.21},{bl:1677.30, br:2854.89, tr:2754.04, tl:1492.20},{bl:1777.74, br:2915.98, tr:2707.90, tl:1405.20},{bl:1882.62, br:2979.61, tr:2666.66, tl:1324.30},{bl:2026.37, br:2775.99, tr:2430.40, tl:1526.90},{bl:2194.73, br:2573.85, tr:2196.84, tl:1745.56},{bl:2375.76, br:2380.83, tr:1967.39, tl:1968.89},{bl:2569.01, br:2199.32, tr:1743.56, tl:2196.63},{bl:2770.16, br:2032.46, tr:1527.90, tl:2428.16},{bl:2978.29, br:1884.09, tr:1324.44, tl:2662.71},{bl:2917.76, br:1781.24, tr:1406.66, tl:2700.32},{bl:2857.92, br:1681.46, tr:1493.23, tl:2745.44},{bl:2802.34, br:1585.10, tr:1584.15, tl:2797.53},{bl:2751.35, br:1493.21, tr:1677.70, tl:2852.59},{bl:2705.21, br:1406.26, tr:1779.89, tl:2912.37},{bl:2664.05, br:1325.42, tr:1887.10, tl:2977.01},]
Computing… This may take several minutesFitness: 0.6102115 in 100
Fitness: 0.6102115 in 200
Fitness: 0.6102115 in 300
Fitness: 0.6102115 in 400
Fitness: 0.6102115 in 500
Fitness: 0.6102115 in 600
Fitness: 0.6102115 in 700
Fitness: 0.6102115 in 800
Fitness: 0.6102115 in 900
Fitness: 0.6102115 in 1000
Calibration values:
Fitness: 0.6102115237225831
Maslow_tlX: -0.4
Maslow_tlY: 2391.0
Maslow_trX: 3571.1
Maslow_trY: 2393.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3572.0
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
CLBM:[{bl:2145.06, br:2145.97, tr:2152.41, tl:2151.75},{bl:2081.23, br:2084.12, tr:2220.89, tl:2218.72},{bl:1871.47, br:2299.34, tr:2424.89, tl:2028.25},{bl:1941.66, br:2359.12, tr:2364.29, tl:1949.16},{bl:2020.33, br:2422.86, tr:2303.39, tl:1875.20},{bl:2215.95, br:2222.92, tr:2085.61, tl:2080.65},{bl:2421.47, br:2027.40, tr:1875.74, tl:2297.99},{bl:2359.98, br:1948.34, tr:1946.40, tl:2358.52},{bl:2299.15, br:1874.29, tr:2025.40, tl:2423.79},{bl:2243.65, br:1807.09, tr:2110.48, tl:2492.38},{bl:2019.81, br:2022.30, tr:2297.39, tl:2298.39},{bl:1802.80, br:2245.81, tr:2496.34, tl:2110.23},{bl:1595.40, br:2472.69, tr:2702.26, tl:1936.21},{bl:1674.63, br:2521.62, tr:2640.46, tl:1844.78},{bl:1755.29, br:2576.62, tr:2580.23, tl:1757.51},{bl:1843.95, br:2637.02, tr:2524.58, tl:1674.94},{bl:1934.48, br:2702.55, tr:2474.15, tl:1598.02},{bl:2108.67, br:2499.57, tr:2245.61, tl:1803.97},{bl:2298.21, br:2300.34, tr:2021.64, tl:2021.18},{bl:2496.22, br:2111.87, tr:1804.84, tl:2246.37},{bl:2701.85, br:1937.54, tr:1597.62, tl:2472.68},{bl:2638.75, br:1846.23, tr:1676.61, tl:2520.35},{bl:2578.47, br:1758.95, tr:1760.16, tl:2575.44},{bl:2522.93, br:1676.47, tr:1847.25, tl:2636.21},{bl:2472.50, br:1599.66, tr:1939.41, tl:2700.04},{bl:2427.55, br:1529.19, tr:2030.22, tl:2769.25},{bl:2193.99, br:1745.07, tr:2197.76, tl:2572.01},{bl:1964.46, br:1969.02, tr:2378.08, tl:2379.18},{bl:1740.48, br:2197.57, tr:2571.28, tl:2197.89},{bl:1524.72, br:2428.29, tr:2772.86, tl:2031.28},{bl:1320.94, br:2662.55, tr:2980.96, tl:1883.27},{bl:1401.18, br:2703.31, tr:2920.60, tl:1780.40},{bl:1488.76, br:2748.38, tr:2860.69, tl:1680.56},{bl:1582.68, br:2798.42, tr:2805.08, tl:1584.21},{bl:1677.30, br:2854.89, tr:2754.04, tl:1492.20},{bl:1777.74, br:2915.98, tr:2707.90, tl:1405.20},{bl:1882.62, br:2979.61, tr:2666.66, tl:1324.30},{bl:2026.37, br:2775.99, tr:2430.40, tl:1526.90},{bl:2194.73, br:2573.85, tr:2196.84, tl:1745.56},{bl:2375.76, br:2380.83, tr:1967.39, tl:1968.89},{bl:2569.01, br:2199.32, tr:1743.56, tl:2196.63},{bl:2770.16, br:2032.46, tr:1527.90, tl:2428.16},{bl:2978.29, br:1884.09, tr:1324.44, tl:2662.71},{bl:2917.76, br:1781.24, tr:1406.66, tl:2700.32},{bl:2857.92, br:1681.46, tr:1493.23, tl:2745.44},{bl:2802.34, br:1585.10, tr:1584.15, tl:2797.53},{bl:2751.35, br:1493.21, tr:1677.70, tl:2852.59},{bl:2705.21, br:1406.26, tr:1779.89, tl:2912.37},{bl:2664.05, br:1325.42, tr:1887.10, tl:2977.01},{bl:2628.26, br:1251.95, tr:1991.75, tl:3045.75},{bl:2388.28, br:1468.25, tr:2127.65, tl:2846.86},{bl:2150.37, br:1691.92, tr:2288.47, tl:2650.40},{bl:1915.51, br:1922.29, tr:2465.24, tl:2463.70},{bl:1685.12, br:2155.77, tr:2650.79, tl:2289.08},{bl:1461.23, br:2391.16, tr:2847.02, tl:2129.57},{bl:1247.13, br:2630.29, tr:3051.12, tl:1988.86},{bl:1049.23, br:2868.06, tr:3257.64, tl:1871.03},{bl:1135.09, br:2898.14, tr:3200.34, tl:1758.64},{bl:1228.23, br:2934.24, tr:3140.81, tl:1647.97},{bl:1324.77, br:2977.61, tr:3085.21, tl:1539.48},{bl:1428.63, br:3024.29, tr:3033.72, tl:1433.71},{bl:1534.09, br:3075.58, tr:2986.59, tl:1331.30},{bl:1642.49, br:3132.16, tr:2944.01, tl:1233.01},{bl:1753.94, br:3192.13, tr:2906.19, tl:1139.99},{bl:1869.89, br:3255.87, tr:2873.31, tl:1053.60},{bl:1985.42, br:3052.99, tr:2631.69, tl:1251.70},{bl:2124.42, br:2848.55, tr:2391.70, tl:1467.20},{bl:2288.01, br:2651.97, tr:2153.81, tl:1691.13},{bl:2459.99, br:2465.06, tr:1919.31, tl:1921.01},{bl:2647.56, br:2290.25, tr:1688.87, tl:2154.66},{bl:2842.86, br:2130.50, tr:1465.17, tl:2390.02},{bl:3044.88, br:1989.41, tr:1251.39, tl:2627.82},{bl:3254.13, br:1871.28, tr:1053.40, tl:2866.92},{bl:3196.87, br:1758.86, tr:1140.49, tl:2896.07},{bl:3137.37, br:1648.29, tr:1229.33, tl:2934.00},{bl:3081.76, br:1539.77, tr:1325.53, tl:2976.32},{bl:3030.31, br:1434.03, tr:1429.75, tl:3021.99},{bl:2983.22, br:1331.69, tr:1535.14, tl:3073.27},{bl:2940.68, br:1233.47, tr:1642.26, tl:3129.25},{bl:2902.91, br:1140.48, tr:1754.17, tl:3189.28},{bl:2870.16, br:1054.05, tr:1865.71, tl:3253.99},]
Computing… This may take several minutesFitness: 0.4725467 in 100
Fitness: 0.4737645 in 200
Fitness: 0.4741878 in 300
Fitness: 0.4745793 in 400
Fitness: 0.4757331 in 500
Fitness: 0.4768456 in 600
Fitness: 0.4777706 in 700
Fitness: 0.4785551 in 800
Fitness: 0.4793435 in 900
Fitness: 0.4799464 in 1000
Fitness: 0.4805248 in 1100
Fitness: 0.4810545 in 1200
Fitness: 0.4815387 in 1300
Fitness: 0.4819522 in 1400
Fitness: 0.4823175 in 1500
Fitness: 0.4826642 in 1600
Fitness: 0.4830009 in 1700
Fitness: 0.4833393 in 1800
Fitness: 0.4836281 in 1900
Fitness: 0.4839172 in 2000
Fitness: 0.4841917 in 2100
Fitness: 0.4844244 in 2200
Fitness: 0.4846465 in 2300
Fitness: 0.4848180 in 2400
Fitness: 0.4849591 in 2500
Fitness: 0.4851011 in 2600
Fitness: 0.4852163 in 2700
Fitness: 0.4853244 in 2800
Fitness: 0.4854297 in 2900
Fitness: 0.4855139 in 3000
Fitness: 0.4855993 in 3100
Fitness: 0.4856683 in 3200
Fitness: 0.4857296 in 3300
Fitness: 0.4857567 in 3400
Fitness: 0.4857779 in 3500
Fitness: 0.4857963 in 3600
Fitness: 0.4858185 in 3700
Fitness: 0.4858357 in 3800
Fitness: 0.4858508 in 3900
Fitness: 0.4858683 in 4000
Fitness: 0.4858862 in 4100
Fitness: 0.4859061 in 4200
Fitness: 0.4859225 in 4300
Fitness: 0.4859369 in 4400
Fitness: 0.4859491 in 4500
Fitness: 0.4859609 in 4600
Fitness: 0.4859757 in 4700
Fitness: 0.4859909 in 4800
Fitness: 0.4860102 in 4900
Fitness: 0.4860279 in 5000
Fitness: 0.4860471 in 5100
Fitness: 0.4860627 in 5200
Fitness: 0.4860792 in 5300
Fitness: 0.4860988 in 5400
Fitness: 0.4861255 in 5500
Fitness: 0.4861541 in 5600
Fitness: 0.4861837 in 5700
Fitness: 0.4862137 in 5800
Fitness: 0.4862435 in 5900
Fitness: 0.4862739 in 6000
Fitness: 0.4863021 in 6100
Fitness: 0.4863328 in 6200
Fitness: 0.4863608 in 6300
Fitness: 0.4863871 in 6400
Fitness: 0.4864132 in 6500
Fitness: 0.4864360 in 6600
Fitness: 0.4864577 in 6700
Fitness: 0.4864791 in 6800
Fitness: 0.4864987 in 6900
Fitness: 0.4865181 in 7000
Fitness: 0.4865380 in 7100
Fitness: 0.4865566 in 7200
Fitness: 0.4865756 in 7300
Fitness: 0.4865920 in 7400
Fitness: 0.4866080 in 7500
Fitness: 0.4866248 in 7600
Fitness: 0.4866402 in 7700
Fitness: 0.4866562 in 7800
Fitness: 0.4866718 in 7900
Fitness: 0.4866867 in 8000
Fitness: 0.4867016 in 8100
Fitness: 0.4867163 in 8200
Fitness: 0.4867287 in 8300
Fitness: 0.4867419 in 8400
Fitness: 0.4867545 in 8500
Fitness: 0.4867656 in 8600
Fitness: 0.4867765 in 8700
Fitness: 0.4867854 in 8800
Fitness: 0.4867961 in 8900
Fitness: 0.4868084 in 9000
Fitness: 0.4868228 in 9100
Fitness: 0.4868392 in 9200
Fitness: 0.4868555 in 9300
Fitness: 0.4868741 in 9400
Fitness: 0.4868932 in 9500
Fitness: 0.4869138 in 9600
Fitness: 0.4869340 in 9700
Fitness: 0.4869577 in 9800
Fitness: 0.4869815 in 9900
Fitness: 0.4870083 in 10000
Fitness: 0.4870354 in 10100
Fitness: 0.4870661 in 10200
Fitness: 0.4870960 in 10300
Fitness: 0.4871303 in 10400
Fitness: 0.4871652 in 10500
Fitness: 0.4872036 in 10600
Fitness: 0.4872439 in 10700
Fitness: 0.4872873 in 10800
Fitness: 0.4873345 in 10900
Fitness: 0.4873827 in 11000
Fitness: 0.4874363 in 11100
Fitness: 0.4874926 in 11200
Fitness: 0.4875533 in 11300
Fitness: 0.4876127 in 11400
Fitness: 0.4876803 in 11500
Fitness: 0.4877521 in 11600
Fitness: 0.4878281 in 11700
Fitness: 0.4879027 in 11800
Fitness: 0.4879733 in 11900
Fitness: 0.4880408 in 12000
Fitness: 0.4881076 in 12100
Fitness: 0.4881729 in 12200
Fitness: 0.4882356 in 12300
Fitness: 0.4882992 in 12400
Fitness: 0.4883590 in 12500
Fitness: 0.4884165 in 12600
Fitness: 0.4884729 in 12700
Fitness: 0.4885272 in 12800
Fitness: 0.4885761 in 12900
Fitness: 0.4886229 in 13000
Fitness: 0.4886704 in 13100
Fitness: 0.4887154 in 13200
Fitness: 0.4887610 in 13300
Fitness: 0.4888042 in 13400
Fitness: 0.4888491 in 13500
Fitness: 0.4888908 in 13600
Fitness: 0.4889321 in 13700
Fitness: 0.4889742 in 13800
Fitness: 0.4890178 in 13900
Fitness: 0.4890593 in 14000
Fitness: 0.4890986 in 14100
Fitness: 0.4891384 in 14200
Fitness: 0.4891791 in 14300
Fitness: 0.4892194 in 14400
Fitness: 0.4892570 in 14500
Fitness: 0.4892994 in 14600
Fitness: 0.4893370 in 14700
Fitness: 0.4893741 in 14800
Fitness: 0.4894137 in 14900
Fitness: 0.4894517 in 15000
Fitness: 0.4894899 in 15100
Fitness: 0.4895249 in 15200
Fitness: 0.4895601 in 15300
Fitness: 0.4895996 in 15400
Fitness: 0.4896369 in 15500
Fitness: 0.4896702 in 15600
Fitness: 0.4897061 in 15700
Fitness: 0.4897421 in 15800
Fitness: 0.4897775 in 15900
Fitness: 0.4898107 in 16000
Fitness: 0.4898436 in 16100
Fitness: 0.4898794 in 16200
Fitness: 0.4899146 in 16300
Fitness: 0.4899467 in 16400
Fitness: 0.4899789 in 16500
Fitness: 0.4900109 in 16600
Fitness: 0.4900443 in 16700
Fitness: 0.4900777 in 16800
Fitness: 0.4901085 in 16900
Fitness: 0.4901404 in 17000
Fitness: 0.4901709 in 17100
Fitness: 0.4902018 in 17200
Fitness: 0.4902334 in 17300
Fitness: 0.4902620 in 17400
Fitness: 0.4902916 in 17500
Fitness: 0.4903244 in 17600
Fitness: 0.4903508 in 17700
Fitness: 0.4903807 in 17800
Fitness: 0.4904102 in 17900
Fitness: 0.4904386 in 18000
Fitness: 0.4904648 in 18100
Fitness: 0.4904933 in 18200
Fitness: 0.4905207 in 18300
Fitness: 0.4905474 in 18400
Fitness: 0.4905744 in 18500
Fitness: 0.4906005 in 18600
Fitness: 0.4906266 in 18700
Fitness: 0.4906537 in 18800
Fitness: 0.4906791 in 18900
Fitness: 0.4907020 in 19000
Fitness: 0.4907280 in 19100
Fitness: 0.4907534 in 19200
Fitness: 0.4907783 in 19300
Fitness: 0.4908011 in 19400
Fitness: 0.4908240 in 19500
Fitness: 0.4908487 in 19600
Fitness: 0.4908709 in 19700
Fitness: 0.4908949 in 19800
Fitness: 0.4909180 in 19900
Fitness: 0.4909411 in 20000
Fitness: 0.4909641 in 20100
Fitness: 0.4909869 in 20200
Fitness: 0.4910134 in 20300
Fitness: 0.4910379 in 20400
Fitness: 0.4910631 in 20500
Fitness: 0.4910855 in 20600
Fitness: 0.4911084 in 20700
Fitness: 0.4911298 in 20800
Fitness: 0.4911524 in 20900
Fitness: 0.4911746 in 21000
Fitness: 0.4911976 in 21100
Fitness: 0.4912181 in 21200
Fitness: 0.4912400 in 21300
Fitness: 0.4912617 in 21400
Fitness: 0.4912794 in 21500
Fitness: 0.4912981 in 21600
Fitness: 0.4913159 in 21700
Fitness: 0.4913316 in 21800
Fitness: 0.4913496 in 21900
Fitness: 0.4913655 in 22000
Fitness: 0.4913821 in 22100
Fitness: 0.4913981 in 22200
Fitness: 0.4914131 in 22300
Fitness: 0.4914286 in 22400
Fitness: 0.4914435 in 22500
Fitness: 0.4914585 in 22600
Fitness: 0.4914720 in 22700
Fitness: 0.4914865 in 22800
Fitness: 0.4915000 in 22900
Fitness: 0.4915130 in 23000
Fitness: 0.4915266 in 23100
Fitness: 0.4915394 in 23200
Fitness: 0.4915510 in 23300
Fitness: 0.4915651 in 23400
Fitness: 0.4915768 in 23500
Fitness: 0.4915884 in 23600
Fitness: 0.4916001 in 23700
Fitness: 0.4916112 in 23800
Fitness: 0.4916221 in 23900
Fitness: 0.4916326 in 24000
Fitness: 0.4916436 in 24100
Fitness: 0.4916538 in 24200
Fitness: 0.4916638 in 24300
Fitness: 0.4916729 in 24400
Fitness: 0.4916828 in 24500
Fitness: 0.4916922 in 24600
Fitness: 0.4917013 in 24700
Fitness: 0.4917100 in 24800
Fitness: 0.4917188 in 24900
Fitness: 0.4917275 in 25000
Fitness: 0.4917356 in 25100
Fitness: 0.4917431 in 25200
Fitness: 0.4917507 in 25300
Fitness: 0.4917577 in 25400
Fitness: 0.4917646 in 25500
Fitness: 0.4917713 in 25600
Fitness: 0.4917772 in 25700
Fitness: 0.4917831 in 25800
Fitness: 0.4917887 in 25900
Fitness: 0.4917940 in 26000
Fitness: 0.4917993 in 26100
Fitness: 0.4918047 in 26200
Fitness: 0.4918102 in 26300
Fitness: 0.4918151 in 26400
Fitness: 0.4918198 in 26500
Fitness: 0.4918250 in 26600
Fitness: 0.4918297 in 26700
Fitness: 0.4918344 in 26800
Fitness: 0.4918389 in 26900
Fitness: 0.4918437 in 27000
Fitness: 0.4918483 in 27100
Fitness: 0.4918526 in 27200
Fitness: 0.4918570 in 27300
Fitness: 0.4918610 in 27400
Fitness: 0.4918652 in 27500
Fitness: 0.4918692 in 27600
Fitness: 0.4918729 in 27700
Fitness: 0.4918773 in 27800
Fitness: 0.4918809 in 27900
Fitness: 0.4918849 in 28000
Fitness: 0.4918885 in 28100
Fitness: 0.4918922 in 28200
Fitness: 0.4918958 in 28300
Fitness: 0.4918992 in 28400
Fitness: 0.4919026 in 28500
Fitness: 0.4919061 in 28600
Fitness: 0.4919092 in 28700
Fitness: 0.4919125 in 28800
Fitness: 0.4919155 in 28900
Fitness: 0.4919190 in 29000
Fitness: 0.4919218 in 29100
Fitness: 0.4919249 in 29200
Fitness: 0.4919279 in 29300
Fitness: 0.4919310 in 29400
Fitness: 0.4919339 in 29500
Fitness: 0.4919367 in 29600
Fitness: 0.4919395 in 29700
Fitness: 0.4919424 in 29800
Fitness: 0.4919451 in 29900
Fitness: 0.4919479 in 30000
Fitness: 0.4919505 in 30100
Fitness: 0.4919529 in 30200
Fitness: 0.4919556 in 30300
Fitness: 0.4919579 in 30400
Fitness: 0.4919605 in 30500
Fitness: 0.4919629 in 30600
Fitness: 0.4919650 in 30700
Fitness: 0.4919675 in 30800
Fitness: 0.4919698 in 30900
Fitness: 0.4919720 in 31000
Fitness: 0.4919743 in 31100
Fitness: 0.4919764 in 31200
Fitness: 0.4919787 in 31300
Fitness: 0.4919808 in 31400
Fitness: 0.4919828 in 31500
Fitness: 0.4919849 in 31600
Fitness: 0.4919869 in 31700
Fitness: 0.4919889 in 31800
Fitness: 0.4919908 in 31900
Fitness: 0.4919926 in 32000
Fitness: 0.4919944 in 32100
Fitness: 0.4919963 in 32200
Fitness: 0.4919982 in 32300
Fitness: 0.4919998 in 32400
Fitness: 0.4920015 in 32500
Fitness: 0.4920032 in 32600
Fitness: 0.4920050 in 32700
Fitness: 0.4920065 in 32800
Fitness: 0.4920081 in 32900
Fitness: 0.4920097 in 33000
Fitness: 0.4920112 in 33100
Fitness: 0.4920128 in 33200
Fitness: 0.4920143 in 33300
Fitness: 0.4920157 in 33400
Fitness: 0.4920172 in 33500
Fitness: 0.4920187 in 33600
Fitness: 0.4920201 in 33700
Fitness: 0.4920215 in 33800
Fitness: 0.4920228 in 33900
Fitness: 0.4920240 in 34000
Fitness: 0.4920253 in 34100
Fitness: 0.4920266 in 34200
Fitness: 0.4920279 in 34300
Fitness: 0.4920291 in 34400
Fitness: 0.4920302 in 34500
Fitness: 0.4920314 in 34600
Fitness: 0.4920326 in 34700
Fitness: 0.4920337 in 34800
Fitness: 0.4920348 in 34900
Fitness: 0.4920359 in 35000
Fitness: 0.4920369 in 35100
Fitness: 0.4920379 in 35200
Fitness: 0.4920390 in 35300
Fitness: 0.4920400 in 35400
Fitness: 0.4920410 in 35500
Fitness: 0.4920420 in 35600
Fitness: 0.4920429 in 35700
Fitness: 0.4920439 in 35800
Fitness: 0.4920447 in 35900
Fitness: 0.4920458 in 36000
Fitness: 0.4920466 in 36100
Fitness: 0.4920474 in 36200
Fitness: 0.4920484 in 36300
Fitness: 0.4920492 in 36400
Fitness: 0.4920500 in 36500
Fitness: 0.4920508 in 36600
Fitness: 0.4920516 in 36700
Fitness: 0.4920524 in 36800
Fitness: 0.4920533 in 36900
Fitness: 0.4920541 in 37000
Fitness: 0.4920548 in 37100
Fitness: 0.4920555 in 37200
Fitness: 0.4920563 in 37300
Fitness: 0.4920570 in 37400
Fitness: 0.4920577 in 37500
Fitness: 0.4920584 in 37600
Fitness: 0.4920592 in 37700
Fitness: 0.4920598 in 37800
Fitness: 0.4920605 in 37900
Fitness: 0.4920612 in 38000
Fitness: 0.4920619 in 38100
Fitness: 0.4920624 in 38200
Fitness: 0.4920631 in 38300
Fitness: 0.4920638 in 38400
Fitness: 0.4920644 in 38500
Fitness: 0.4920650 in 38600
Fitness: 0.4920656 in 38700
Fitness: 0.4920662 in 38800
Fitness: 0.4920668 in 38900
Fitness: 0.4920674 in 39000
Fitness: 0.4920680 in 39100
Fitness: 0.4920685 in 39200
Fitness: 0.4920690 in 39300
Fitness: 0.4920695 in 39400
Fitness: 0.4920700 in 39500
Fitness: 0.4920705 in 39600
Fitness: 0.4920710 in 39700
Fitness: 0.4920715 in 39800
Fitness: 0.4920720 in 39900
Fitness: 0.4920725 in 40000
Fitness: 0.4920729 in 40100
Fitness: 0.4920734 in 40200
Fitness: 0.4920739 in 40300
Fitness: 0.4920743 in 40400
Fitness: 0.4920749 in 40500
Fitness: 0.4920753 in 40600
Fitness: 0.4920757 in 40700
Fitness: 0.4920761 in 40800
Fitness: 0.4920765 in 40900
Fitness: 0.4920769 in 41000
Fitness: 0.4920773 in 41100
Fitness: 0.4920778 in 41200
Fitness: 0.4920781 in 41300
Fitness: 0.4920785 in 41400
Fitness: 0.4920789 in 41500
Fitness: 0.4920793 in 41600
Fitness: 0.4920796 in 41700
Fitness: 0.4920800 in 41800
Fitness: 0.4920803 in 41900
Fitness: 0.4920807 in 42000
Fitness: 0.4920810 in 42100
Fitness: 0.4920813 in 42200
Fitness: 0.4920816 in 42300
Fitness: 0.4920820 in 42400
Fitness: 0.4920822 in 42500
Fitness: 0.4920825 in 42600
Fitness: 0.4920828 in 42700
Fitness: 0.4920832 in 42800
Fitness: 0.4920835 in 42900
Fitness: 0.4920838 in 43000
Fitness: 0.4920840 in 43100
Fitness: 0.4920843 in 43200
Fitness: 0.4920847 in 43300
Fitness: 0.4920849 in 43400
Fitness: 0.4920851 in 43500
Fitness: 0.4920854 in 43600
Fitness: 0.4920857 in 43700
Fitness: 0.4920859 in 43800
Fitness: 0.4920862 in 43900
Fitness: 0.4920864 in 44000
Fitness: 0.4920866 in 44100
Fitness: 0.4920869 in 44200
Fitness: 0.4920871 in 44300
Fitness: 0.4920873 in 44400
Fitness: 0.4920875 in 44500
Fitness: 0.4920878 in 44600
Fitness: 0.4920880 in 44700
Fitness: 0.4920882 in 44800
Fitness: 0.4920884 in 44900
Fitness: 0.4920886 in 45000
Fitness: 0.4920888 in 45100
Fitness: 0.4920890 in 45200
Fitness: 0.4920892 in 45300
Fitness: 0.4920894 in 45400
Fitness: 0.4920895 in 45500
Fitness: 0.4920898 in 45600
Fitness: 0.4920899 in 45700
Fitness: 0.4920901 in 45800
Fitness: 0.4920903 in 45900
Fitness: 0.4920904 in 46000
Fitness: 0.4920906 in 46100
Fitness: 0.4920907 in 46200
Fitness: 0.4920909 in 46300
Fitness: 0.4920910 in 46400
Fitness: 0.4920912 in 46500
Fitness: 0.4920913 in 46600
Fitness: 0.4920914 in 46700
Fitness: 0.4920916 in 46800
Fitness: 0.4920917 in 46900
Fitness: 0.4920918 in 47000
Fitness: 0.4920919 in 47100
Fitness: 0.4920921 in 47200
Fitness: 0.4920922 in 47300
Fitness: 0.4920924 in 47400
Fitness: 0.4920925 in 47500
Fitness: 0.4920926 in 47600
Fitness: 0.4920927 in 47700
Fitness: 0.4920929 in 47800
Fitness: 0.4920930 in 47900
Fitness: 0.4920931 in 48000
Fitness: 0.4920932 in 48100
Fitness: 0.4920933 in 48200
Fitness: 0.4920934 in 48300
Fitness: 0.4920935 in 48400
Fitness: 0.4920936 in 48500
Fitness: 0.4920937 in 48600
Fitness: 0.4920938 in 48700
Fitness: 0.4920940 in 48800
Fitness: 0.4920941 in 48900
Fitness: 0.4920942 in 49000
Fitness: 0.4920943 in 49100
Fitness: 0.4920943 in 49200
Fitness: 0.4920944 in 49300
Fitness: 0.4920945 in 49400
Fitness: 0.4920946 in 49500
Fitness: 0.4920946 in 49600
Fitness: 0.4920947 in 49700
Fitness: 0.4920948 in 49800
Fitness: 0.4920950 in 49900
Fitness: 0.4920951 in 50000
Fitness: 0.4920951 in 50100
Fitness: 0.4920952 in 50200
Fitness: 0.4920953 in 50300
Fitness: 0.4920953 in 50400
Fitness: 0.4920953 in 50500
Fitness: 0.4920953 in 50600
Fitness: 0.4920953 in 50700
Fitness: 0.4920953 in 50800
Fitness: 0.4920953 in 50900
Fitness: 0.4920953 in 51000
Fitness: 0.4920953 in 51100
Fitness: 0.4920953 in 51200
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
