How to hold smaller than full sheet wood for cncing
Anyone have any ideas or techniques for holding a smaller than 4x8 sheet of wood for the machine? Want to see what is out there before i figure out something.
Thanks
I’ve used screws in areas which are out of cutting area also nails using a nail gun and double sided adhesive tape which is surprising strong
You may also want to think about a frame of scrap material around the piece that you are cutting. That would let you cut to the edge without the sled tipping over. Alternatively, you could help the sled stay upright by hand.
there is a line of plastic nails (Raptor IIRC) that won’t damage the bit when
you cut through them.
If you are screwing the workpiece down, using brass screws won’t damage the bit
when you hit them like steel screws will.
