I'm trying to select a path
I use KrabzCAM which I discovered in the channel’s videos and I managed some nice cuts. On the other hand I am blocked by the selection with the mouse, it is imprecise when the paths are superimposed. Ideally I would like to be able to select a path from a list. A solution with KrabzCAM or should I try with another software?
I want to make pockets.
Hi, KrabzCAM does not currently have a way to separate two identical paths on top of each other.
But if you open the paths in inkscape (or some other svg editor), you can assign different colors to different paths.
You can then reopen the colored paths in KrabzCAM and cycle through them (grouped by color) using Shift+A,…as discussed here.
Hope this can be helpful
-Marius
