Nesting in krabzcam?
any way to nest things you want to cut out in Krabzcam to cut down on waste?
You can move things around in inkscape or crabz Cam so cuts were inside voids. I would select the inner shape and set up paths in order from the inside out. If you paths are different colors in a vector drawing you can step through them in krabzcam or other Cam programs. Does that help?
I was wondering if there was a button to auto do that, but thank you, that does help, i will do it like that if i don’t just end up getting another nesting cam
