Hi, everybody. Brand new here. Finally had time to start setting everything up, but I could use some help.
I got Arduino IDE 1.8.5 and maslow firmware 1.15 running on a windows 10 laptop.
I try to run the compiler to load firmware onto board and keep getting this error.
Arduino: 1.8.5 (Windows 10), Board: “Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jmcla\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jmcla\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jmcla\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\jmcla\AppData\Local\Temp\arduino_build_807768 -warnings=all -build-cache C:\Users\jmcla\AppData\Local\Temp\arduino_cache_624173 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\jmcla\AppData\Local\Temp\Temp1_Firmware-1.15.zip\Firmware-1.15\cnc_ctrl_v1\cnc_ctrl_v1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jmcla\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jmcla\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jmcla\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\jmcla\AppData\Local\Temp\arduino_build_807768 -warnings=all -build-cache C:\Users\jmcla\AppData\Local\Temp\arduino_cache_624173 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.1.1 -prefs=runtime.tools.avr-gcc.path=C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2 -verbose C:\Users\jmcla\AppData\Local\Temp\Temp1_Firmware-1.15.zip\Firmware-1.15\cnc_ctrl_v1\cnc_ctrl_v1.ino
Using board ‘mega’ from platform in folder: C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Using core ‘arduino’ from platform in folder: C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21
Detecting libraries used…
“C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino” “-IC:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\mega” “C:\Users\jmcla\AppData\Local\Temp\arduino_build_807768\sketch\cnc_ctrl_v1.ino.cpp” -o “nul”
“C:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR “-IC:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino” “-IC:\Users\jmcla\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\variants\mega” “C:\Users\jmcla\AppData\Local\Temp\arduino_build_807768\sketch\cnc_ctrl_v1.ino.cpp” -o “C:\Users\jmcla\AppData\Local\Temp\arduino_build_807768\preproc\ctags_target_for_gcc_minus_e.cpp”
C:\Users\jmcla\AppData\Local\Temp\Temp1_Firmware-1.15.zip\Firmware-1.15\cnc_ctrl_v1\cnc_ctrl_v1.ino:36:20: fatal error: Maslow.h: No such file or directory
#include “Maslow.h”
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Completely lost on where to go from here. Thanks in advance for any help you might be able to give.
