After a day where almost everything that could go wrong went wrong, I finally got to try out a calibration on my M4. My frame is a 5’x10’ utility trailer, I measure my anchor points and I’m reasonably sure that I put in 2870x1420 for the frame dimensions, and 700x350, 9x9. I thought the 350 was a reasonable value based on the M4 frame calculator and just doubled it for the X value.
I thought the calibration was going well, the only thing I noticed was the motor current threshold of 4000 was exceeded 3 times, always on the Bottom Right axis.
It appeared to get all the way through the calibration, and reported:
Calibration complete
Calibration values:
Fitness: 1.6785950428066916
Maslow_tlX: 0.6
Maslow_tlY: 1421.9
Maslow_trX: 2877.9
Maslow_trY: 1416.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 2876.6
Maslow_brY: 0.0
These values have been automatically saved for you.
[MSG:INFO: Calibration complete]
[MSG:ERR: Unable to move safely, stopping calibration]
So I guess what I’m wondering is did the calibration actually complete? If I put it back on the frame, will I be able to move it and possibly cut something? Did I choose a calibration area too large for the size of my frame, or do I need to disassemble and check the lower right axis for binding? I’m planning to build a frame, but putting anchors in the corners of the utility trailer was the quickest way to test things.
I have the messages for the entire calibration if that will help, and I plan to do more testing tomorrow, I’ll update with more info then.
Thanks in advance for any advice.
Russ
