Running into 2 issues today while trying to calibrate on latest firmware 70.2. Vertical Setup
When retract cables during calibration consistently when one of the lower cables are more loose it will stop before becoming fully tensioned. Then the other lower cable will tension and then the first lower cable tensions fully before measurement. Maybe not an issue as all cables are tensioned when measurement is taken but wanted to identify this observation. Always the same cable so I might need to go rebuild that motor arm…
Much Bigger Issue. I am running into an emergency stop condition while calibrating. Red Blinking light as well. Had to reset machine and it happened twice now. Never ran into this issue in previous calibration attempts on earlier firmware versions. See Log below but doesn’t say much on the why.
Also it was really hard to copy logs as it just kept generating the error even when I clicked the Stop Button. Not sure how to make this stop.
Serial Messages
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Top Right pulled tight with offset -1329.728]
[MSG:INFO: Bottom Right pulled tight with offset -1383.731]
[MSG:INFO: Bottom Left pulled tight with offset -1718.525]
[MSG:INFO: Top Left pulled tight with offset -1765.893]
[MSG:INFO: Center point deviation: TL: 0.226 TR: 0.076 BL: -55.680 BR: 43.082]
[MSG:ERR: Unable to move safely, stopping calibration]
No heartbeat from machine in 10 seconds. Please check connection.
