Initial Setup - One Channel of board does not aplly voltage to motor
Hi All,
I built my Maslow 4.1 a few months back, never had the time to turn it on.
Today I finally started on the actual set-up:
I upgraded to Firmware 1.16 without problems.
I followed the instructions to pull in all belts, which is where I am stuck: 3 belts are being pulled in (at 1300), on belt (Top Left, Uppermost arm does not move).
After searching a bit on the forum, I moved up the force to 1500 and 1800 and tried again. Still no movement. I noticed that all the other motors spools turn a little bit (looking into the case of the motors), when clicking “retract all”.
To find out if the motor is broken, I connected the motor to TR (second from below) and tried retract all again. This time the motor moved for about 10cm (at 1300 force), with force 1800 I got the belt to be pulled in fully. At the same time, the motor “TR”, which I connected to channel TL did not move at all anymore.
Using the manual command $TRO / $TRI (BR/BL/TL etc…) I got all three motors at BR, BL and TR to extend / retract the cables a few millimeters for testing (the log ends with “[MSG:INFO: 200]”. Using the command $TLO / $TLI does nothing (The logs ends with [MSG:INFO: 201]).
I then tried to measure with a multi-meter, if the motor at channel TL gets some voltage. To do this I extended all four belts for ca 10mm (using the above commands, physically switching the connection for the non-working channel). and hit “Retract All”. This gives me a few seconds to measure voltage at the soldering points on the backside of the board: All working motors show a few volts of current, except for Channel TL.
Conclusion: All motors and encoder cables work. The channel “TL” either is broken, or I am doing something wrong.
A pointer in the right direction is certainly appreciated.
Best Regards
Jochen
PS: an excerpt from the logs (I can make the full log available)
[MSG:INFO: Current z-axis position loaded as: -75.000]
[MSG:INFO: No saved belt positions found in NVS - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Starting Maslow Version v1.16]
Retract All
[MSG:INFO: Requesting state change from Retracting Belts to Retracting Belts]
[MSG:INFO: Succeeded]
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
[MSG:INFO: Bottom Right pulled tight with offset 0.043]
[MSG:INFO: Top Right pulled tight with offset -0.011]
#Comment: State of machine never stops “State: Retracting”
Extend All
[MSG:INFO: Requesting state change from Retracting Belts to Extending Belts]
[MSG:INFO: Cannot extend the belts until they have been retracted]
Hmm that is really strange. It sounds like you have done an excellent job of testing. I would say for sure it’s a board issue issue, but the only thing that makes me hesitate is this bit:
That means that the board is measuring some current going to that motor.
I’m going to DM you a code for a free replacement right now, but it also might be worth poking at it a little more while it’s in transit in case we learn something else.
Hi Bar,
thanks again for the speedy answer!
I’ll be happy to test further to (maybe) isolate the error without a replacement board. I would be needing your advice what to try though. Currently I am pretty much out of ideas.
What I can do is post a (commented) log, once I am not a new user anymore :slight_smile:
Best Regards
Jochen
It might be worth taking apart the spools and sanding & polish the belt spools so they spin easily by hand. I don’t think it’s the root cause but might help and certainly will help avoid some other issues.
Dano
The only other thing that I can think to check is the motor connectors.
Where are you measuring the voltage when you measure it?
Hi Dano,
That is a good suggestion (saw the topic about getting the retracting force to below 1000). I will certainly try this, tonoptimize operations.
For the current problem: Connecting to another motor, all four arms get full retraction with force 1800. So I would rule out too much friction on the arms for now.
Jochen
Hi Bar,
I was measuring on the underside, at the soldering pins directly beneath the connector (I was thnking maybe a blind soldering spot).
Jochen
A blind solder is a good guess for what could be going on.
Does moving the connector around have any impact?
Hi All,
I might have the same problem. One of the Z-axis connectors is not working for me. It’s not the motor itself, both motors work if I test them in the other Z-axis connector. Tried to wiggle the connector but it doesn’t help. Any ideas? The board says V1.10b, have firmware 1.17
Thanks, Ivo
the first batch of 4.1 boards had this as a common failure mode, @bar will
probably contact you shortly with a code for a free replacement.
Ivo wrote:
Yup! That sounds like the issue to me. I will DM you a code for a free replacement right now!
Thanks @bar @dlang
Hi All, Hi Bar,
just to note, the new board works perfectly on first try. Without re-assembly, all motors now work with force 1300. (which is an unexpected improvement: the other board needed 1800).
I will consider the issue closed.
I can try my first setup on the weekend now :slight_smile:
Thanks again Bar for the quick help.
Cheers Jochen
