I apologize for my question. Just finished connecting the machine. I came across this problem: the machine instead of going to the right and going down to the left upwards and vice versa. Rearranged ports now goes up and down as needed, but right to the left - inversion. How to fix the problem? Thank you in advance.
Welcome to the Forum!
MP1 should be the right motor standing in front of the frame. MP3 the left motor.
Another reason could be the setting top-feed/bottom-feed.
If your slack chains are on the sides, set top-feed, if they are across the top set bottom-feed.
Kind regards, Gero
Thank you! Where could i find that setting?
Itâs set during the calibration. You can also set it in the Advanced settings.
In GroundControl click on âSettingsâ and then on the grey bar on the title âMaslow Stettingâ. A âhiddenâ menu will show up with âAdvanced Stettingsâ. You will find Top/Bottom there.
Super! It works! Thank you for such a detailed instruction.
Thank you for your question!
It brings up thoughts like âwhy is that not in the main settingsâ as it is a part of the setup.
Itâs questions like this that have brought this project forward constantly improving.
Reward us by sharing your first steps and cuts.
Any feedback is more then welcome and has information on how to get even better.
Hoping for some posts at my-first-cuts soon
Kind regards, Gero
Looks good, but what happened on the left side of the âMâ?
I forgot that i didnt install Z axe yet
