First cut on the Maslow. This originally was not going to be my first cut but I was getting pretty frustrated and just wanted to see it cut something. Holes in the picture are from the failed sled cut.
1.) Could not get the router to center on the plywood. After spending a couple hours redoing everything and troubleshooting, I come to find out the I entered Inches instead of mm for the measurement from the center of the motor to the top of the plywood.
2.) I had a chain wrap when running the benchmark. The bungee string did not work that well. When the router was on one side of the board, one bungee was too loose and the other was so tight it was at the point of snapping. I ended up running counter weights off of the center pulleys and down behind the plywood(works great).
3.) When I was running the Sled cutout I got a usb connection lost error and had to re calibrate the chain links. Unfortunately I was unable to restart the cut after calibration because Ground Control closed out and lost the home position of the project.
