Is there a way to raise the z after stopping a cut mid cut?
if i stop a cut mid cut is there a way to raise the z without power cycling?
How did you stop? If you press the stop button you should be able to raise the z axis using the regular controls
I’ve pressed the red square, and or just the far left pause button, i haven’t used the stop in the config menu yet, which one is the right one to be able to continue?
Pressing this stop button while cutting should reset the machine to a state where you can move it around with the arrow buttons and start a new cut.
