Hi. Im attaching here at the bottom the results i received. I just cut another sample (a square) I did a 5 x 5 square. I use easel from inventables for software. The square is supposed to be 5 x 5 and ends up being 5 x 4.75. I cut outside the path to get the 5x5 square and it didnt come to 5 x 5 .
results below
Serial Messages
Index.html Version: 0.88
[MSG:INFO: FluidNC v0.88]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Axi[MSG:INFO: Channel auto report interval set to 50 ms]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Axi[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:INFO: WiFi on]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Bottom Right pulled tight with offset -1886.180]
[MSG:INFO: Top Right pulled tight with offset -1986.347]
[MSG:INFO: Bottom Left pulled tight with offset -2133.013]
[MSG:INFO: Top Left pulled tight with offset -2233.986]
[MSG:INFO: All belts extended to 2100.000mm]
[MSG:INFO: Machine Position found as X: -2.973 Y: -126.508]
[MSG:INFO: Center point off by: TL: 55.857 TR: 60.161 BL: -68.961 BR: -52.536]
[MSG:INFO: Machine Position computed as X: -2.641 Y: -98.852]
[MSG:INFO: Measuring Frame Flex]
[MSG:INFO: Flex measurement: TLBR: 0.014 TRBL: 1.044]
CLBM:[{bl:2139.32, br:2158.70, tr:2253.40, tl:2251.34},{bl:2275.11, br:2037.99, tr:2139.33, tl:2370.80},{bl:2357.78, br:2124.14, tr:2046.56, tl:2293.29},{bl:2239.68, br:2242.71, tr:2165.63, tl:2168.62},{bl:2120.12, br:2365.30, tr:2291.64, tl:2045.55},{bl:2029.25, br:2288.81, tr:2374.10, tl:2132.55},]
Computing… This may take several minutesFitness: 0.1314851 in 100
Fitness: 0.1423353 in 200
Fitness: 0.1532007 in 300
Fitness: 0.1642196 in 400
Fitness: 0.1755348 in 500
Fitness: 0.1889039 in 600
Fitness: 0.2039364 in 700
Fitness: 0.2244508 in 800
Fitness: 0.2244508 in 900
Fitness: 0.2244508 in 1000
Fitness: 0.2244508 in 1100
Fitness: 0.2244508 in 1200
Fitness: 0.2244508 in 1300
Fitness: 0.2244508 in 1400
Fitness: 0.2244508 in 1500
Fitness: 0.2244508 in 1600
Fitness: 0.2244508 in 1700
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
Calibration values:
Fitness: 0.2244507840817798
Maslow_tlX: 11.6
Maslow_tlY: 2518.7
Maslow_trX: 3769.1
Maslow_trY: 2256.7
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3630.8
Maslow_brY: 0.0
RestartingFitness: 0.2447758 in 100
Fitness: 0.2447758 in 200
Fitness: 0.2447758 in 300
Fitness: 0.2447758 in 400
Fitness: 0.2447758 in 500
Fitness: 0.2447758 in 600
Fitness: 0.2447758 in 700
Fitness: 0.2447758 in 800
Fitness: 0.2447758 in 900
Fitness: 0.2447758 in 1000
Calibration values:
Fitness: 0.24477583502461195
Maslow_tlX: 18.7
Maslow_tlY: 2491.7
Maslow_trX: 3767.2
Maslow_trY: 2261.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3656.9
Maslow_brY: 0.0
RestartingFitness: 0.2841818 in 100
Fitness: 0.2841818 in 200
Fitness: 0.2841818 in 300
Fitness: 0.2841818 in 400
Fitness: 0.2841818 in 500
Fitness: 0.2841818 in 600
Fitness: 0.2841818 in 700
Fitness: 0.2841818 in 800
Fitness: 0.2841818 in 900
Fitness: 0.2841818 in 1000
Calibration values:
Fitness: 0.2841817988264542
Maslow_tlX: 30.2
Maslow_tlY: 2466.0
Maslow_trX: 3760.2
Maslow_trY: 2283.5
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3684.1
Maslow_brY: 0.0
RestartingFitness: 0.3239379 in 100
Fitness: 0.3239379 in 200
Fitness: 0.3239379 in 300
Fitness: 0.3239379 in 400
Fitness: 0.3239379 in 500
Fitness: 0.3239379 in 600
Fitness: 0.3239379 in 700
Fitness: 0.3239379 in 800
Fitness: 0.3239379 in 900
Fitness: 0.3239379 in 1000
Calibration values:
Fitness: 0.323937945151475
Maslow_tlX: 25.4
Maslow_tlY: 2443.1
Maslow_trX: 3753.8
Maslow_trY: 2295.2
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3695.0
Maslow_brY: 0.0
RestartingFitness: 0.3616451 in 100
Fitness: 0.3616451 in 200
Fitness: 0.3616451 in 300
Fitness: 0.3616451 in 400
Fitness: 0.3616451 in 500
Fitness: 0.3616451 in 600
Fitness: 0.3616451 in 700
Fitness: 0.3616451 in 800
Fitness: 0.3616451 in 900
Fitness: 0.3616451 in 1000
Calibration values:
Fitness: 0.36164508007183715
Maslow_tlX: 7.7
Maslow_tlY: 2440.3
Maslow_trX: 3738.8
Maslow_trY: 2318.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3679.7
Maslow_brY: 0.0
RestartingFitness: 0.3710277 in 100
Fitness: 0.3710277 in 200
Fitness: 0.3710277 in 300
Fitness: 0.3710277 in 400
Fitness: 0.3710277 in 500
Fitness: 0.3710277 in 600
Fitness: 0.3710277 in 700
Fitness: 0.3710277 in 800
Fitness: 0.3710277 in 900
Fitness: 0.3710277 in 1000
Calibration values:
Fitness: 0.37102766649421304
Maslow_tlX: 39.9
Maslow_tlY: 2440.3
Maslow_trX: 3727.9
Maslow_trY: 2341.7
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3711.0
Maslow_brY: 0.0
RestartingFitness: 0.2908236 in 100
Fitness: 0.2908236 in 200
Fitness: 0.2908236 in 300
Fitness: 0.2908236 in 400
Fitness: 0.2908236 in 500
Fitness: 0.2908236 in 600
Fitness: 0.2908236 in 700
Fitness: 0.2908236 in 800
Fitness: 0.2908236 in 900
Fitness: 0.2908236 in 1000
Calibration values:
Fitness: 0.2908235908884504
Maslow_tlX: 71.4
Maslow_tlY: 2484.4
Maslow_trX: 3721.0
Maslow_trY: 2350.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3710.6
Maslow_brY: 0.0
RestartingFitness: 0.3692017 in 100
Fitness: 0.3692017 in 200
Fitness: 0.3692017 in 300
Fitness: 0.3692017 in 400
Fitness: 0.3692017 in 500
Fitness: 0.3692017 in 600
Fitness: 0.3692017 in 700
Fitness: 0.3692017 in 800
Fitness: 0.3692017 in 900
Fitness: 0.3692017 in 1000
Calibration values:
Fitness: 0.3692017374781446
Maslow_tlX: 45.5
Maslow_tlY: 2495.4
Maslow_trX: 3693.4
Maslow_trY: 2396.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3679.4
Maslow_brY: 0.0
RestartingFitness: 0.3796460 in 100
Fitness: 0.3796460 in 200
Fitness: 0.3796460 in 300
Fitness: 0.3796460 in 400
Fitness: 0.3796460 in 500
Fitness: 0.3796460 in 600
Fitness: 0.3796460 in 700
Fitness: 0.3796460 in 800
Fitness: 0.3796460 in 900
Fitness: 0.3796460 in 1000
Calibration values:
Fitness: 0.37964603701738686
Maslow_tlX: 33.9
Maslow_tlY: 2473.2
Maslow_trX: 3702.3
Maslow_trY: 2380.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3683.3
Maslow_brY: 0.0
RestartingFitness: 0.5081497 in 100
Fitness: 0.5336234 in 200
Fitness: 0.5336234 in 300
Fitness: 0.5336234 in 400
Fitness: 0.5336234 in 500
Fitness: 0.5336234 in 600
Fitness: 0.5336234 in 700
Fitness: 0.5336234 in 800
Fitness: 0.5336234 in 900
Fitness: 0.5336234 in 1000
Fitness: 0.5336234 in 1100
Calibration values:
Fitness: 0.5336233967818667
Maslow_tlX: 6.9
Maslow_tlY: 2431.1
Maslow_trX: 3695.9
Maslow_trY: 2391.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3685.2
Maslow_brY: 0.0
A command to save these values has been successfully sent for you. Please check for any error messages.
[MSG:INFO: Machine Position found as X: -172.056 Y: -83.404]
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
CLBM:[{bl:2139.32, br:2158.70, tr:2253.40, tl:2251.34},{bl:2275.11, br:2037.99, tr:2139.33, tl:2370.80},{bl:2357.78, br:2124.14, tr:2046.56, tl:2293.29},{bl:2239.68, br:2242.71, tr:2165.63, tl:2168.62},{bl:2120.12, br:2365.30, tr:2291.64, tl:2045.55},{bl:2029.25, br:2288.81, tr:2374.10, tl:2132.55},{bl:2213.56, br:2188.20, tr:2189.79, tl:2222.02},{bl:2155.09, br:2121.56, tr:2255.68, tl:2291.57},{bl:1986.28, br:2291.11, tr:2417.70, tl:2140.48},{bl:2051.07, br:2353.27, tr:2357.18, tl:2062.83},{bl:2124.02, br:2419.82, tr:2296.55, tl:1990.75},{bl:2283.73, br:2260.71, tr:2123.26, tl:2154.05},{bl:2450.85, br:2102.27, tr:1952.67, tl:2328.21},{bl:2390.83, br:2024.49, tr:2020.99, tl:2390.40},{bl:2330.07, br:1952.41, tr:2097.12, tl:2456.43},]
Computing… This may take several minutesFitness: 0.7307313 in 100
Fitness: 0.7324436 in 200
Fitness: 0.7324436 in 300
Fitness: 0.7324436 in 400
Fitness: 0.7324436 in 500
Fitness: 0.7324436 in 600
Fitness: 0.7324436 in 700
Fitness: 0.7324436 in 800
Fitness: 0.7324436 in 900
Fitness: 0.7324436 in 1000
Fitness: 0.7324436 in 1100
Calibration values:
Fitness: 0.7324435657725898
Maslow_tlX: 7.9
Maslow_tlY: 2431.1
Maslow_trX: 3696.8
Maslow_trY: 2391.6
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3686.8
Maslow_brY: 0.0
[MSG:INFO: Machine Position found as X: 196.894 Y: -124.528]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
CLBM:[{bl:2139.32, br:2158.70, tr:2253.40, tl:2251.34},{bl:2275.11, br:2037.99, tr:2139.33, tl:2370.80},{bl:2357.78, br:2124.14, tr:2046.56, tl:2293.29},{bl:2239.68, br:2242.71, tr:2165.63, tl:2168.62},{bl:2120.12, br:2365.30, tr:2291.64, tl:2045.55},{bl:2029.25, br:2288.81, tr:2374.10, tl:2132.55},{bl:2213.56, br:2188.20, tr:2189.79, tl:2222.02},{bl:2155.09, br:2121.56, tr:2255.68, tl:2291.57},{bl:1986.28, br:2291.11, tr:2417.70, tl:2140.48},{bl:2051.07, br:2353.27, tr:2357.18, tl:2062.83},{bl:2124.02, br:2419.82, tr:2296.55, tl:1990.75},{bl:2283.73, br:2260.71, tr:2123.26, tl:2154.05},{bl:2450.85, br:2102.27, tr:1952.67, tl:2328.21},{bl:2390.83, br:2024.49, tr:2020.99, tl:2390.40},{bl:2330.07, br:1952.41, tr:2097.12, tl:2456.43},{bl:2279.32, br:1886.77, tr:2172.26, tl:2524.46},{bl:2098.01, br:2056.32, tr:2329.23, tl:2374.43},{bl:1922.11, br:2233.91, tr:2487.39, tl:2221.23},{bl:1751.36, br:2418.09, tr:2651.73, tl:2076.02},{bl:1817.04, br:2470.80, tr:2592.82, tl:1988.84},{bl:1891.21, br:2528.37, tr:2531.66, tl:1905.82},{bl:1970.71, br:2589.88, tr:2475.29, tl:1827.60},{bl:2054.40, br:2655.73, tr:2424.06, tl:1754.79},{bl:2200.17, br:2496.76, tr:2243.61, tl:1917.71},{bl:2355.47, br:2337.14, tr:2063.55, tl:2091.66},{bl:2518.69, br:2184.17, tr:1887.51, tl:2271.89},{bl:2687.05, br:2039.42, tr:1716.79, tl:2455.26},{bl:2627.50, br:1951.96, tr:1786.09, tl:2507.63},{bl:2566.25, br:1868.77, tr:1863.73, tl:2563.71},{bl:2509.71, br:1790.37, tr:1945.67, tl:2625.35},{bl:2458.28, br:1717.52, tr:2032.16, tl:2690.43},]
Computing… This may take several minutesFitness: 0.7055364 in 100
Fitness: 0.7163644 in 200
Fitness: 0.7246830 in 300
Fitness: 0.7325787 in 400
Fitness: 0.7415560 in 500
Fitness: 0.7516172 in 600
Fitness: 0.7602375 in 700
Fitness: 0.7711365 in 800
Fitness: 0.7891163 in 900
Fitness: 0.8166913 in 1000
Fitness: 0.8369944 in 1100
Fitness: 0.8630228 in 1200
Fitness: 0.8966723 in 1300
Fitness: 0.9559029 in 1400
Fitness: 0.9951343 in 1500
Fitness: 1.0209614 in 1600
Fitness: 1.0281480 in 1700
Fitness: 1.0281480 in 1800
Fitness: 1.0281480 in 1900
Fitness: 1.0281480 in 2000
Fitness: 1.0281480 in 2100
Fitness: 1.0281480 in 2200
Fitness: 1.0281480 in 2300
Fitness: 1.0281480 in 2400
Fitness: 1.0281480 in 2500
Fitness: 1.0281480 in 2600
Calibration values:
Fitness: 1.0281480195915662
Maslow_tlX: 6.5
Maslow_tlY: 2405.3
Maslow_trX: 3696.8
Maslow_trY: 2392.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3702.6
Maslow_brY: 0.0
[MSG:INFO: Machine Position found as X: 411.348 Y: -253.882]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
CLBM:[{bl:2139.32, br:2158.70, tr:2253.40, tl:2251.34},{bl:2275.11, br:2037.99, tr:2139.33, tl:2370.80},{bl:2357.78, br:2124.14, tr:2046.56, tl:2293.29},{bl:2239.68, br:2242.71, tr:2165.63, tl:2168.62},{bl:2120.12, br:2365.30, tr:2291.64, tl:2045.55},{bl:2029.25, br:2288.81, tr:2374.10, tl:2132.55},{bl:2213.56, br:2188.20, tr:2189.79, tl:2222.02},{bl:2155.09, br:2121.56, tr:2255.68, tl:2291.57},{bl:1986.28, br:2291.11, tr:2417.70, tl:2140.48},{bl:2051.07, br:2353.27, tr:2357.18, tl:2062.83},{bl:2124.02, br:2419.82, tr:2296.55, tl:1990.75},{bl:2283.73, br:2260.71, tr:2123.26, tl:2154.05},{bl:2450.85, br:2102.27, tr:1952.67, tl:2328.21},{bl:2390.83, br:2024.49, tr:2020.99, tl:2390.40},{bl:2330.07, br:1952.41, tr:2097.12, tl:2456.43},{bl:2279.32, br:1886.77, tr:2172.26, tl:2524.46},{bl:2098.01, br:2056.32, tr:2329.23, tl:2374.43},{bl:1922.11, br:2233.91, tr:2487.39, tl:2221.23},{bl:1751.36, br:2418.09, tr:2651.73, tl:2076.02},{bl:1817.04, br:2470.80, tr:2592.82, tl:1988.84},{bl:1891.21, br:2528.37, tr:2531.66, tl:1905.82},{bl:1970.71, br:2589.88, tr:2475.29, tl:1827.60},{bl:2054.40, br:2655.73, tr:2424.06, tl:1754.79},{bl:2200.17, br:2496.76, tr:2243.61, tl:1917.71},{bl:2355.47, br:2337.14, tr:2063.55, tl:2091.66},{bl:2518.69, br:2184.17, tr:1887.51, tl:2271.89},{bl:2687.05, br:2039.42, tr:1716.79, tl:2455.26},{bl:2627.50, br:1951.96, tr:1786.09, tl:2507.63},{bl:2566.25, br:1868.77, tr:1863.73, tl:2563.71},{bl:2509.71, br:1790.37, tr:1945.67, tl:2625.35},{bl:2458.28, br:1717.52, tr:2032.16, tl:2690.43},{bl:2090.46, br:2073.07, tr:2333.83, tl:2356.86},{bl:2210.28, br:2201.73, tr:2194.81, tl:2209.90},]
Computing… This may take several minutesFitness: 1.0456805 in 100
Fitness: 1.0456805 in 200
Fitness: 1.0456805 in 300
Fitness: 1.0456805 in 400
Fitness: 1.0456805 in 500
Fitness: 1.0456805 in 600
Fitness: 1.0456805 in 700
Fitness: 1.0456805 in 800
Fitness: 1.0456805 in 900
Fitness: 1.0456805 in 1000
Calibration values:
Fitness: 1.0456804457024678
Maslow_tlX: 6.3
Maslow_tlY: 2405.2
Maslow_trX: 3696.8
Maslow_trY: 2392.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3702.7
Maslow_brY: 0.0
[MSG:INFO: Machine Position found as X: -0.007 Y: -4.834]
