I just tried using v0.88 in anger today (been doing lots of other software stuff instead).
Anyway, I couldn’t get calibration to work at all, very low values, stuck in a loop etc.
After switching both FW and WebUI back to 0.87 I saw this in the config panel - so I’m guessing there’s something wrong with the algorithm …
Yeah - I don’t use a square frame.
There’s also the problem of the ‘extend what you want’ value. If you go too large, you’ll get a “home position was more than 100mm off from what was expected”.
Also, if you redo calibration after changing some value (like the ‘extend what you want setting’), after having previously just refreshed your browser tab to get out of the infinite calibration loop, then the calibration process doesn’t quite seem to know where in the calibration process it is up to (i.e. which waypoint).
Then if you “turn it off and on again” and rerun the calibration, your frame comes out square, as above.
I suspect that calibration doesn’t like verticalish setups. As per the comment for the Maslow_::takeSlackFunc() function (shown below), if every belt has been extended the same, but you only tighten up the ‘bottom’ belts, and you 'extend’ed too far, then you’re guaranteed to be well off home position.
* This function is used to take up the slack in the belts and confirm that the calibration values are resonable
* It does this by retracting the two lower belts and taking a measurement. The machine's position is then calculated
* from the lenghts of the two upper belts. The lengths of the two lower belts are then compared to their expected calculated lengths
* If the difference is beyond a threshold we know that the stored anchor point locations do not match the real dimensons and and error is thrown
Here’s an abridged log from the earlier step trying to get calibration to happen.
Serial Messages
Index.html Version: 0.88
[MSG:INFO: FluidNC v0.88]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:TP-Link_5CB2]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.1.100]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: WiFi on]
[MSG:INFO: Bottom Left pulled tight with offset -0.097]
[MSG:INFO: Bottom Right pulled tight with offset 0.021]
[MSG:INFO: Top Left pulled tight with offset -0.054]
[MSG:INFO: Top Right pulled tight with offset 0.183]
[MSG:INFO: Top Right pulled tight with offset -0.043]
[MSG:INFO: Bottom Right pulled tight with offset -0.032]
[MSG:INFO: Top Left pulled tight with offset 0.054]
[MSG:INFO: Bottom Left pulled tight with offset -0.011]
[MSG:INFO: All belts extended to 1850.000mm]
[MSG:INFO: Machine Position found as X: -3.190 Y: -95.000]
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
CLBM:[{bl:1818.47, br:1812.35, tr:2053.41, tl:2051.27},{bl:1940.29, br:1702.17, tr:1958.86, tl:2151.52},{bl:2020.75, br:1795.64, tr:1845.40, tl:2055.25},{bl:1917.00, br:1903.00, tr:1941.69, tl:1946.43},{bl:1932.94, br:2012.13, tr:2050.55, tl:1842.88},{bl:1706.15, br:1930.14, tr:2153.93, tl:1949.90},{bl:1917.83, br:1895.83, tr:1944.76, tl:1954.39},{bl:1833.84, br:1817.70, tr:2034.11, tl:2043.28},{bl:1649.25, br:2000.17, tr:2210.11, tl:1889.68},{bl:1733.43, br:2076.72, tr:2128.51, tl:1785.96},{bl:1836.35, br:2164.17, tr:2044.81, tl:1685.24},{bl:2009.89, br:1998.68, tr:1853.08, tl:1855.97},{bl:2186.26, br:1826.64, tr:1675.52, tl:2048.85},{bl:2109.12, br:1723.08, tr:1769.35, tl:2132.74},{bl:2025.92, br:1630.25, tr:1874.41, tl:2220.55},]
Computing... This may take several minutesFitness: 0.0455547 in 100
Fitness: 0.0518002 in 200
Fitness: 0.0572877 in 300
Fitness: 0.0637077 in 400
Fitness: 0.0699161 in 500
Fitness: 0.0752554 in 600
Fitness: 0.0798869 in 700
Fitness: 0.0835706 in 800
Fitness: 0.0871514 in 900
Fitness: 0.0905585 in 1000
Fitness: 0.0935381 in 1100
Fitness: 0.0964651 in 1200
Fitness: 0.0991577 in 1300
Fitness: 0.1015063 in 1400
Fitness: 0.1034053 in 1500
Fitness: 0.1053125 in 1600
Fitness: 0.1072665 in 1700
Fitness: 0.1087769 in 1800
Fitness: 0.1099579 in 1900
Fitness: 0.1104388 in 2000
Fitness: 0.1104876 in 2100
Fitness: 0.1108009 in 2200
Fitness: 0.1110359 in 2300
Fitness: 0.1119925 in 2900
Fitness: 0.1120731 in 3000
Fitness: 0.1128548 in 3500
Fitness: 0.1130009 in 3600
Fitness: 0.1139631 in 4500
Fitness: 0.1140941 in 4600
Fitness: 0.1149535 in 5900
Fitness: 0.1150067 in 6000
Fitness: 0.1157534 in 16600
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
Calibration values:
Fitness: 0.1157534213672829
Maslow_tlX: 8.5
Maslow_tlY: 2200.6
Maslow_trX: 3254.2
Maslow_trY: 2093.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3167.0
Maslow_brY: 0.0
RestartingFitness: 0.1208519 in 100
Fitness: 0.1208519 in 200
Fitness: 0.1208519 in 1000
Calibration values:
Fitness: 0.12085193994978287
Maslow_tlX: -5.3
Maslow_tlY: 2150.8
Maslow_trX: 3247.2
Maslow_trY: 2104.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3187.7
Maslow_brY: 0.0
RestartingFitness: 0.1405453 in 100
Fitness: 0.1405453 in 200
Fitness: 0.1405453 in 1000
Calibration values:
Fitness: 0.1405452596705082
Maslow_tlX: -6.5
Maslow_tlY: 2107.8
Maslow_trX: 3254.3
Maslow_trY: 2088.5
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3212.3
Maslow_brY: 0.0
RestartingFitness: 0.1338986 in 100
Fitness: 0.1338986 in 200
Fitness: 0.1338986 in 1000
Calibration values:
Fitness: 0.1338986462766522
Maslow_tlX: -25.3
Maslow_tlY: 2067.7
Maslow_trX: 3277.5
Maslow_trY: 2051.7
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3223.7
Maslow_brY: 0.0
RestartingFitness: 0.0890136 in 100
Fitness: 0.0893031 in 200
Fitness: 0.0893031 in 1100
Calibration values:
Fitness: 0.08930309490055931
Maslow_tlX: -89.1
Maslow_tlY: 2017.5
Maslow_trX: 3211.9
Maslow_trY: 2157.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3189.4
Maslow_brY: 0.0
RestartingFitness: 0.0978734 in 100
Fitness: 0.0978734 in 200
Fitness: 0.0978734 in 900
