Hello,
I just picked up a Maslow4 that is said to have been calibrated but never cut. I disassembled enough to add a dust collector shroud and the v.8 belt guides that I printed in PLA. I have not done anything else other than give it a once over to make sure it looks to be assembled correctly. I also have 1/8" bits that I plan to use with 1/4 to 1/8 adapter sleeves. I will also print out a router button pusher, but have not yet.
Is/are there any other mechanical improvements/accessories that I should add now? Also, what version of code would give me the best chance of success? I plan to use the M4 on my garage floor in the horizontal configuration, with belt pins spaced to allow full 4 x 8 ft sheets of plywood.
Thanks in advance!
-Ben
