Keyboard case and some weird calibration stuff
Images here: https://www.instagram.com/p/BYEb71kntqg/?taken-by=designfrontier
The issues I am seeing are…
  1. top left corner the bit pulls 1/2 of its width to high
  2. the right side is .5mm narrower then the cut should be and then the right side (distance between is about 230mm)
  3. corners on the outside are a little inconsistent…
  4. z is within .25mm all over. Not bad but probably the best I can expect with my current router setup. Thinking about a more solid mount for the z motor to the router body but haven’t started working it yet.
But generally impressed with where it is right now! If anyone has ideas for what could be causing those issues I am all ears. Haven’t been able to get anything like them in the simulator.
