Ill try a larger grid and keep you posted.
I recalibrated, did an aircut and every seemed ok.
Homed the unit. Then lost connection. Disconnected for some reason. Could not get the log.
Tried to connect again and it would not connect through my wifi router. Disconnect and connected via AP mode.
It connects for a second and then disconnects again. Keeps doing this.
I disconnected power and tried several times. Not working.
Any suggestions.
what changed?
including, are you running the router now and weren’t before??
did you move something in the house so that there may be something between the
router and the maslow that wasn’t there before?
Are you by any chance using a shopvac for dust collection?
The static electricity created by air flowing through the hose can cause that kind of behavior.
nope all the same, and it disconnects event when in AP mode and im standing next to it with laptop.
Then you need to connect via USB and see what the maslow thinks is happening.
