M2 Upgrade Z Axis Depth
My first test cut on the M2 Upgrade and my Z Axis is digging way too deep. I believe this is caused by the difference in gears since before my maslow was attached directly to the Rigid Depth Screw, but I’m having a hard time figuring out what that ratio is supposed to be or where to set it.
Any advice?
Makerverse? You have to enter the z axis calibration information
Webcontrol, change z axis pitch to 8
Webcontrol, and Oh boy did I get that one wrong!
My guess was 3:1 ratio so I used the guidance in the Meticulous Z instructions and set it to -24.
Thank you!!
It depends on the gearing for the belt on the motor. The screws are typically, but not always 8 mm per rev. I geared my meticulous with a 60 and a 20 tooth gear, but the m2 appears to have a 1:1 gearing.
I went with -8 and it went 2x deeper than anticipated (on a test piece of scrap) reaching 18mm depth in 3x 3mm passes so I think I’ll need to halve it.
Worse case I’ll tear it down and count teeth but you got me on the right track!
I just use a micrometer and move and measure
