The new firmware is loaded and calibration is running.
First I ran a test nc file. Got a ton of errors.
Err. Position error on () axis exceeded 1mm, error is ().
It was all axis and the reported error is between 1 and1.5.
What is it telling me?
Itās telling you that I need to tune the PID controller ![]()
Thatās totally normal, basically when the machine changes direction suddenly it will sometimes overshoot on one of the belts and you will get that warning. You can totally ignore them, I just didnāt want to solve the issue by hiding the error message since the real solution is to improve the PID tuning.
Calibration worked.
Home button does not seem to.
Excellent!
Tell me more!
@bar
Iāve been away from it and when I came back upgraded to .75 and changed my frame from 12x8 to 9.5x6. The movements for calibration are unexpected. The first measurement appears to be in the center and looks normal, it the drops down and makes another, then this.
What is happening here?
Serial Messages
[MSG:INFO: FluidNC v0.74 (Maslow-Main-dddcbc15-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Config messages ran]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: C<Alarm|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:hudson]
[MSG:INFO: Connecting.]
[MSG:INFO: Connectingā¦]
[MSG:INFO: Connected - IP is 192.168.0.19]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Bottom Left pulled tight with offset -1395.251]
[MSG:INFO: Top Left pulled tight with offset -1432.806]
[MSG:INFO: Bottom Right pulled tight with offset -1736.562]
[MSG:INFO: Top Right pulled tight with offset -1758.463]
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.186 TR: 0.332 BL: -3.967 BR: -3.631]
[MSG:ERR: Unable to move safely, stopping calibration]
board: Maslow
name: Maslow S3 Board
meta:
Maslow_vertical: false
maslow_calibration_grid_width_mm_X: 2000.000000
maslow_calibration_grid_height_mm_Y: 1000.000000
maslow_calibration_grid_size: 9
Maslow_brX: 2992.000000
Maslow_brY: 0.000000
Maslow_brZ: 78.000000
Maslow_tlX: 0.000000
Maslow_tlY: 1708.000000
Maslow_tlZ: 100.000000
Maslow_trX: 2992.000000
Maslow_trY: 1708.000000
Maslow_trZ: 56.000000
Maslow_blX: 0.000000
Maslow_blY: 0.000000
Maslow_blZ: 34.000000
Maslow_Retract_Current_Threshold: 1300
Maslow_Calibration_Current_Threshold: 1500
Maslow_Acceptable_Calibration_Threshold: 0.500000
stepping:
engine: Timed
idle_ms: 240
pulse_us: 4
dir_delay_us: 0
disable_delay_us: 0
segments: 12
uart1:
txd_pin: gpio.1
rxd_pin: gpio.2
rts_pin: NO_PIN
cts_pin: NO_PIN
baud: 115200
mode: 8N1
spi:
miso_pin: gpio.13
mosi_pin: gpio.11
sck_pin: gpio.12
sdcard:
cs_pin: gpio.10
card_detect_pin: NO_PIN
frequency_hz: 8000000
kinematics:
Cartesian:
axes:
shared_stepper_disable_pin: NO_PIN
shared_stepper_reset_pin: NO_PIN
x:
steps_per_mm: 80.000000
max_rate_mm_per_min: 2000.000000
acceleration_mm_per_sec2: 25.000000
max_travel_mm: 2438.399902
soft_limits: false
homing:
cycle: -1
allow_single_axis: true
positive_direction: true
mpos_mm: 0.000000
feed_mm_per_min: 50.000000
seek_mm_per_min: 200.000000
settle_ms: 250
seek_scaler: 1.100000
feed_scaler: 1.100000
motor0:
limit_neg_pin: NO_PIN
limit_pos_pin: NO_PIN
limit_all_pin: NO_PIN
hard_limits: false
pulloff_mm: 1.000000
dc_servo:
timer_ms: 10
y:
max_travel_mm: 1219.199951
soft_limits: false
homing:
cycle: -1
mpos_mm: 0.000000
settle_ms: 250
motor0:
hard_limits: false
null_motor:
z:
steps_per_mm: 100.000000
max_rate_mm_per_min: 400.000000
acceleration_mm_per_sec2: 10.000000
max_travel_mm: 100.000000
soft_limits: false
homing:
cycle: -1
mpos_mm: 0.000000
settle_ms: 250
motor0:
hard_limits: false
tmc_2209:
uart_num: 1
step_pin: gpio.15
direction_pin: gpio.16
disable_pin: NO_PIN
r_sense_ohms: 0.110000
run_amps: 1.000000
hold_amps: 0.500000
microsteps: 1
toff_disable: 0
toff_stealthchop: 5
use_enable: true
addr: 0
run_mode: StealthChop
homing_mode: StealthChop
stallguard: 0
stallguard_debug: false
toff_coolstep: 3
motor1:
hard_limits: false
tmc_2209:
uart_num: 1
step_pin: gpio.46
direction_pin: gpio.38
disable_pin: NO_PIN
run_amps: 1.000000
hold_amps: 0.500000
microsteps: 1
toff_disable: 0
toff_stealthchop: 5
use_enable: true
addr: 1
stallguard: 0
toff_coolstep: 3
control:
safety_door_pin: NO_PIN
reset_pin: NO_PIN
feed_hold_pin: NO_PIN
cycle_start_pin: NO_PIN
macro0_pin: NO_PIN
macro1_pin: NO_PIN
macro2_pin: NO_PIN
macro3_pin: NO_PIN
coolant:
flood_pin: NO_PIN
mist_pin: NO_PIN
delay_ms: 0
probe:
pin: NO_PIN
check_mode_start: true
macros:
startup_line0:
startup_line1:
macro0:
macro1:
macro2:
macro3:
start:
must_home: true
deactivate_parking: false
check_limits: false
parking:
enable: false
axis: Z
target_mpos_mm: -5.000000
rate_mm_per_min: 800.000000
pullout_distance_mm: 5.000000
pullout_rate_mm_per_min: 250.000000
user_outputs:
analog0_pin: NO_PIN
analog1_pin: NO_PIN
analog2_pin: NO_PIN
analog3_pin: NO_PIN
analog0_hz: 5000
analog1_hz: 5000
analog2_hz: 5000
analog3_hz: 5000
digital0_pin: NO_PIN
digital1_pin: NO_PIN
digital2_pin: NO_PIN
digital3_pin: NO_PIN
digital4_pin: NO_PIN
digital5_pin: NO_PIN
digital6_pin: NO_PIN
digital7_pin: NO_PIN
NoSpindle:
arc_tolerance_mm: 0.002000
junction_deviation_mm: 0.010000
verbose_errors: false
report_inches: false
enable_parking_override_control: false
use_line_numbers: false
planner_blocks: 16
The classic - Youāve got āhorizontalā (i.e. on the floor) selected in the config, when by the looks of your setup you need āverticalā
Oh good lord. Thatās a real Homer Simpson moment.
Thanks
