These two values will set how far in from the anchor points in X an Y the corner measurement will be taken…but we’re clearly further off than that would indicate.
Would you mind posting your full maslow.yaml file? It must be something in there, but I’m a bit lost as to what it could be. Maybe if I can look at all the values directly I could find it.
Since you are using the default frame which is very similar to mine you could also try deleting your maslow.yaml file and using just the unedited one that comes with the latest firmware. Might be worth a shot.
When I put the 2000mm and 3000mm in the yaml file, I didn’t haven enough slack and the reason for the extra 50mm.
I was gonna to try and change the X and Y calibration offset. The Left Lower corner of the 4x8’ plywood board is 10in (254mm) away from the Left Lower anchor in the x-axis and 24in (610mm) in the y-axis.
It’s weird because that’s basically exactly what mine is so I would expect it to work.
When you go to hook up the belts you should have a good amount of slack…like several inches of extra which makes me think that something might be off there.
Computing… This may take several minutes
Fitness: 0.05185994917353326 in 100 cycles
Fitness: 0.055213043964903036 in 200 cycles
Fitness: 0.0573813274846064 in 300 cycles
Fitness: 0.05922075430633391 in 400 cycles
Fitness: 0.0612245830259927 in 500 cycles
…and it goes on…
Fitness: 0.20495518956387865 in 51600 cycles
Fitness: 0.20495518956387865 in 51700 cycles
Fitness: 0.20495518956387865 in 51800 cycles
Fitness: 0.20495518956387865 in 51900 cycles
Fitness: 0.20495518956387865 in 52000 cycles
Calibration complete
Basically what that means is that it’s having a hard time fitting the points to the the frame. We’re only talking about a few mm of error so we’re quite close.
Did all four belts seem tight during each time that it took a measurement?
It might be worth doing the exact same thing again and seeing if it’s different. That feels 98% of the way there. One funky measurement could be throwing it off.
