Not at all, it’s counterintuitive. You are 100% correct, that should give you more slack.
But if you do -300 and top and bottom you aren’t going to have any extra slack to make it easy to hook up so it might be worth doing -400 on the lower ones then.
Its on its way. looking much better this time. Thanks again! I’m hoping I will have success this time!
And that helped a ton. I was actually only about 20mm short on the right top, so I’ll bump accordingly. I may try to come up with a configuration for this for anyone else that wants to move where calibration starts. Good easy intro into to the Fluid side of things ![]()
Well, I came in the house to answer this while calibration ran and when I went back out to the garage the maslow was off the right side of the spoilboard stuck in the frame, trying to go up and one of the belts is hopeless tangled.
I’m done for today, no more time to play. Assuming I can get the belt untangled, I will not leave this thing alone on the next time!
Send an email to Anna@maslowcnc.com and we’ll get you some spare belts and spools in the mail ASAP
I was able to get it untangled this morning, but it did really grind up that belt in one place. I think the bad area is in far enough that I can work with it a little while I wait. I’ll email Anna, thanks!
The OOCL New York brought us thousands of spares so we should be set for anyone who needs one for a long time.
