This has been on the back burner for some time, now I’ve finally done it.
Having a removable spindle always allowed for replacing the spindle with something else, such as a pen.
Here’s what I ended up with:
The full kit - main arm support (outer sleeve), inner sleeve with press fit nuts, pen adapter, m4 screws, and springs.
Then a py photo of the inner subassembly
So cool, was going to start working on an adaptation like this myself. Neat to see it working. Thank you for sharing! : ) I want to try sticking a drag knife in there for paper or vinyl. We are building a library of designs and examples in GIT, may I use your pictures and descriptions there? Would you be willing to share your files there at some point?
here is the link to the router library where this project would fit well:
Look up the original M4 router be gone post for details of what I did to set up for a spindle instead of the router - which is something I VERY STRONGLY recommend.
The idea is to redesign the PenMountStaedtlerM.stp mdel to fit your own marker pen. A pen up to around 18mm in diameter should be supportable (that’s what I designed for)
The idea is to redesign the PenMountStaedtlerM.stp mdel to fit your own marker pen. A pen up to around 18mm in diameter should be supportable (that¢s what I designed for)
I have a parametric version of the sleeve and spindle holder in onshape at
it lets you tweak sizes and also select between the 500w brushed spindle and
600w brushless spindle.
I plan to add an option for the pen (copying what lee posted in this thread),
and could add a drag knife version as well if you want
