Hello, I have the maslow 2 and XL frame. I ordered the maslow 4. Can i use the existing frame from the maslow 2 for the maslow 4? Thanks
Is this frame made my MakerMade? I’m not totally familiar with that frame, but with a little modification I’m pretty sure you can use it
MakerMade is a totally different company (which has been using our name) so I’ve never actually seen one of those in person, but I think that it shouldn’t be too hard at all to modify that to make it work. That looks really nicely made.
You will need to add a second set of anchor points on the bottom to anchor the lower belts, but other than that it should work pretty much as is ![]()
