Owner of a pair of Maslows (M2s actually) and a thankful backer of the Maslow 4.
A couple observations/questions- hopefully I haven’t overlooked the answers somewhere- my apologies if I have. Furthermore, I make NO claims that I am smart enough to ‘gotcha’ anyone here- bar or RomanG especially!
So…
There have been multiple mentions that the 4 can be used in a horizontal (tabletop) orientation- which opens up numerous possibilities. However, it seems to me there is a recurring design assumption that it will operate in a near upright (easel) orientation. This manifests primarily in references to top/upper and bottom/lower, or dynamics where a gravity force vector is assumed.
As an example - in update 2’s description of auto calibration it is stated that
“The order in which the belts are pulled tight is important. Here you can see that at the bottom left corner of the sheet it is important that the lower left belt is taught before the lower right belt is pulled tight when taking a measurement.”
(And I’m going to be pedantic and point out “taut” vs. “taught”- roast me on my own inevitable errors!)
This assumes the top two belts are already in tension due to gravity’s effect on the sled and thus the sled’s position is already defined by them as in the Maslow’s fundamental principles. To look at it another way- there is no reason to ‘push’ the sled (which is not possible with chains or belts) into position- it will always hang at the extent of the upper chains/belts at a particular position. So in the example above, the order of operation for the lower belts is constrained by the need to avoid pulling the sled out of this static position.
When in a tabletop orientation, this gravity-provided force is not available to move the sled- all movement has to be accomplished by pulling it into position- and this is of course the power of the Maslow 4 design. But now the order of all four belts is in question, at least for calibration where the geometry is unknown. Has this been considered in regards to the auto-calibration routine?
(I have a couple of ideas- probably closer to opinions- as to methods of addressing this, but I am curious as to others’ thoughts.)
My second question is in regards to the question of the effective ratio of the belt spools and the effect on belt tension vs. motor current.
I understand that the actual movement of the belts is measured directly by encoders, but the gearmotors’ rotation is not directly measured. As the belts are wound and unwound from the spools, the effective diameter of each spool changes, as the belt stacks up. A back-of-a-napkin calculation seems to show that this effective diameter could vary by 50% over the length of the belt.
Again, this has no effect on the accuracy of the length measurement- the encoders are measuring the belt’s movement not the spools’- but it does have an effect on the ratio between motor turns and belt movement, and thus motor current and belt tension. I have no idea how significant this would be in the actual application at hand, but I do know from experience with winches that this is a factor that can have real-world effects.
Again, thanks to both the team and the community and looking forward to this next evolution.
