My first project: a sled for the Maslow
While trying to get everything up and running, I got frustrated by the lack of an easy workflow for retracting and expanding the belts. My frame is vertical, which requires a step ladder to remove the belts. The challenge of putting on the first belt while holding the Maslow in one hand and trying to secure the belt end into the corner with the other hand was a real PITA. Also, when the Maslow is of the frame, I cannot place it anywhere to complete the entire process.
This led me to the idea of keeping the Maslow on the frame and securing it in place to simplify installation. Initially, I used a lashing strap, but I was not satisfied with that solution either.
Therefore, I decided to dedicate my first real Maslow project to creating a Maslow sled holder. And I’m really happy with the result.
The sled is built from several layers of plywood that are glued together. Cutting all the parts took me several weeks of trial and error. I finally understand how to convert my design into gcode! I also encountered some issues with losing the WiFi connection, but with one of the later firmware updates, my cuts went smoothly.
The base is a large circle, and it turned out perfectly. That was really satisfying!
In my initial finished version, I noticed that the Maslow was tipping over when placed on the sled without tension on the belts. Therefore, I added those two pinball machine-like flippers to the sides. Now, the Maslow is securely attached to the sled and locked into place even more effectively.
While working on it, I also tried to integrate another idea I had.
I am using a small circuit with a battery and a speaker. In the center of the sled, I have a strip of copper tape, and on the other end, I have a crocodile clamp that I can attach to the router collet.
Now, I can lower the Z until I hear a beep, making it really easy to set my home Z.
Not sure if all bits are conductive, but for the ones I use know it works great :slight_smile:
It would have been great if I had integrated the component into the wood instead of placing it on the outside, but for now, I’ll leave it as it is.
Now the whole process is a lot easier for me. I still have to use my step ladder, but I have both hands free to install and remove the belts. Retracting and extending are also a lot easier when everything is still on the frame.
If anyone is interested, I can share my design for the sled and the Z-checker.
That is sooo cool! I love the idea of the z-axis depth adjuster. That’s such a great and simple solution.
I was getting worn out doing this too, the fact that my frame is vertical probably makes it a bigger deal because that one part of the hanging process where you are suspending the Maslow between your hand and the belt that goes up to the far corner while you Drag it up so you can hook the other side… That’s a work out, especially with my really big frame so I’m reaching up high.
When I saw this, it just made so much sense. I didn’t make a solution as nice as this, I whipped something together out of some scrap in my shop, but I absolutely Credit this excellent idea.
Mine uses some straps I salvaged from a bad ratchet strap (the ratchet mechanism was broken) and I added some outriggers on the bottom because it wanted to tilt away from the board otherwise.
I just restrung my cables using this and the difference in effort was astonishing. Thank you again for the idea! My execution is not anywhere near as good, but the concept is so solid, even this janky version worked.
That’s awesome!
I’m so happy I could inspire someone, and you can enjoy the benefits of it too!
Btw the outriggers on the bottom is a great idea. My first version did the same so I used heavier wood + the pinball machine flippers. A piece of wood on the bottom would have been a lot easier :smiley:
Hello @marzsman, great project, I was thinking in something like this, and I wanted to ask you if I can get the files to make one like yours?
Thanks in advance.
Thx @Igor_Martin!
Yes, absolutely.
I have no idea where my original exports went, but luckily I still have the 3D project.
I’ll attach a DXF and an SVG. If you want, I can also export the full 3D file.
The wood I used is plywood, and the thickness of the wood from top to bottom is:
18mm → top layer
8mm
18mm
8mm → the big circle
Maslow sled holder
Maslow sled holder.dxf.zip (272.9 KB)
Let me know if you need some extra info
