(Maslow 4 version) one of the 4 arms does not "extand all"
Hello Maslow team,
I recently bought a second-hand Maslow 4.0 (the version with RJ45 encoder connectors) ;
One of the four arms refuses to unspool during Extend All:
  • Retract All works properly on this arm (so the DC gear motor is fine).
  • During Extend All, the motor stays locked when pulling on the belt and only moves a tiny bit when releasing tension.
Here is everything I have already verified and tested:
  1. I swapped both motor and RJ45 encoder cables on the main control board with a working arm → the issue stayed on the exact same physical arm (control board is good).
  2. I replaced the RJ45 Ethernet cable with a known working one → the issue remained.
  3. I opened the arm, cleaned everything, confirmed the belt is wound properly with teeth facing out, glued the original diametrically magnetized magnet back flush into the shallow side of the roller (facing the PCB), and backed off the front housing screws slightly so the roller spins freely.
Everything seems to point to a faulty RJ45 Encoder PCB on this arm.
I’m locked… Would you have advices for me ?
Thank you very much for your help!
Where are you? Someone who has upgraded to 4.1 might be able to provide an RJ45 encoder.
What version of software do you have loaded?
Hi,
I’m in Belgium ;
I have loaded the last firmware version, just a few days ago.
Maybe I can chage the entire arm, but maybe it is not necessary …
Thanks in advance.
Laurent DEBEFVE,
Rue de Tirlemont, 65 - 1350 Noduwez
Belgium
laurentdebefve@hotmail.com
