Morning ,
I have checked all connections and anything obvious . below is the serial file . I tried to upload but it wouldnt allow .
Serial Messages
Index.html Version: 1.04
[MSG:WARN: Bad connection on Bottom Right encoder, failed to read 1 times in the last second]
[MSG:ERR: Emergency stop. Update function not being called enough.1005ms since last call]
[MSG:ERR: Emergency stop. Update function not being called enough.1003ms since last call]
[MSG:WARN: Encoder read failure on Bottom Right]
[MSG:WARN: Encoder read failure on Bottom Left]
[MSG:WARN: Bad connection on Bottom Left encoder, failed to read 1 times in the last second]
[MSG:ERR: Emergency stop. Update function not being called enough.1002ms since last call]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
[MSG:ERR: Emergency stop. Update function not being called enough.1001ms since last call]
[MSG:ERR: Emergency stop. Update function not being called enough.2002ms since last call]
Retract All
