Z probe doesn't work
I built and set up a z probe plate per the instructions in Instructions - How To Make And Set Up A Z-Probe On The M4.
It almost works, but I get an error when the probing routine tries to retract, throwing a “NaN” error for the z retract distance. That value is set in the configuration.
Can someone tell me where that number comes from in the actual code?
My probe settings were 50, 60, 10 and 0.7 for max travel, feed rate, retract distance, and plate thickness. After consideration, I changed the plate thickness to 0 - bottom of sled, but get the same result.
Here is my log:
G38.2 Z-50 F60 P0.1
<Run|MPos:0.401,187.050,40.240,0.000,0.000|FS:60,0>
<Run|MPos:0.401,186.803,30.550,0.000,0.000|FS:36,0|Pn:P|Ov:100,100,100><Run|MPos:0.401,186.796,30.500,0.000,0.000|FS:0,0|Pn:P><Run|MPos:0.402,186.789,30.450,0.000,0.000|FS:0,0|Pn:P><Run|MPos:0.395,186.794,30.400,0.000,0.000|FS:0,0|Pn:P><Run|MPos:0.402,186.800,30.350,0.000,0.000|FS:0,0|Pn:P><Run|MPos:0.403,186.797,30.330,0.000,0.000|FS:0,0|Pn:P><Idle|MPos:0.403,186.797,30.330,0.000,0.000|FS:0,0|Pn:P>[PRB:0.401,186.810,30.600,1.616,0.000:1]$J=G90 G21 F1000 ZNaN
[MSG:INFO: Probe offset applied:]okERROR:2Missing the expected G-code word value or numeric value format is not valid.
Thanks,
Joe
Here is my log:
G38.2 Z-50 F60 P0.1
ok
ERROR:2
I think I ran into a similar problem where it doesn’t accept 0 as the plate
thickness, try setting it to 0.1 or something like that.
Hi David,
I tried that, same result:
G38.2 Z-50 F60 P0.1 <Run|MPos:-159.142,-43.034,30.960,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.142,-43.036,30.940,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.039,30.910,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.045,30.860,0.000,0.000|FS:60,0><Run|MPos:-159.148,-43.039,30.810,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.034,30.760,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.040,30.710,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.045,30.660,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.040,30.610,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.146,-43.045,30.560,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.051,30.510,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.137,-43.046,30.460,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.040,30.410,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.046,30.360,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.051,30.310,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.057,30.260,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.062,30.210,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.046,30.160,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.052,30.110,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.140,-43.057,30.060,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.064,30.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.146,-43.058,29.950,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.064,29.900,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.059,29.850,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.064,29.800,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.059,29.750,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.064,29.700,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.070,29.650,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.075,29.600,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.142,-43.059,29.550,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.064,29.500,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.141,-43.070,29.450,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.076,29.400,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.081,29.350,0.000,0.000|FS:60,0><Run|MPos:-159.147,-43.075,29.300,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.070,29.250,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.076,29.200,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.081,29.150,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.075,29.100,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.145,-43.081,29.050,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.086,29.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.136,-43.082,28.950,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.076,28.900,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.081,28.850,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.087,28.800,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.092,28.750,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.098,28.700,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.082,28.650,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.087,28.600,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.139,-43.093,28.550,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.098,28.500,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.146,-43.092,28.450,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.098,28.400,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.092,28.350,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.098,28.300,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.092,28.250,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.098,28.200,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.103,28.150,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.109,28.100,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.134,-43.104,28.050,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.098,28.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.141,-43.103,27.950,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.109,27.900,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.114,27.850,0.000,0.000|FS:60,0><Run|MPos:-159.147,-43.108,27.800,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.103,27.750,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.109,27.700,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.114,27.650,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.108,27.600,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.144,-43.114,27.550,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.119,27.500,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.143,-43.125,27.450,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.120,27.400,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.114,27.350,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.119,27.300,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.125,27.250,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.130,27.200,0.000,0.000|FS:60,0><Run|MPos:-159.148,-43.124,27.150,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.119,27.100,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.139,-43.125,27.050,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.130,27.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.145,-43.124,26.950,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.130,26.900,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.135,26.850,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.130,26.800,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.124,26.750,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.130,26.700,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.135,26.650,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.141,26.600,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.142,-43.146,26.550,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.129,26.500,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.140,-43.135,26.450,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.140,26.400,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.146,26.350,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.140,26.300,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.145,26.250,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.140,26.200,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.145,26.150,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.139,26.100,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.143,-43.145,26.050,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.150,26.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.143,-43.156,25.950,0.000,0.000|FS:60,0><Run|MPos:-159.134,-43.150,25.900,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.144,25.850,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.151,25.790,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.156,25.740,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.162,25.690,0.000,0.000|FS:60,0><Run|MPos:-159.147,-43.156,25.640,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.149,25.600,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.138,-43.155,25.550,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.160,25.500,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.145,-43.154,25.450,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.160,25.400,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.165,25.350,0.000,0.000|FS:60,0><Run|MPos:-159.136,-43.160,25.300,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.166,25.240,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.160,25.190,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.166,25.140,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.171,25.090,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.141,-43.177,25.040,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.159,25.000,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.139,-43.164,24.950,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.169,24.900,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.175,24.850,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.170,24.790,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.176,24.740,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.170,24.690,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.175,24.640,0.000,0.000|FS:60,0><Run|MPos:-159.136,-43.181,24.590,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.143,-43.175,24.540,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.180,24.490,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.142,-43.185,24.440,0.000,0.000|FS:60,0><Run|MPos:-159.134,-43.180,24.390,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.174,24.340,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.180,24.290,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.185,24.240,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.190,24.190,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.184,24.140,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.179,24.090,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.138,-43.184,24.040,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.190,23.990,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.144,-43.184,23.940,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.189,23.890,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.194,23.840,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.189,23.790,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.194,23.740,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.188,23.690,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.194,23.640,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.199,23.590,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.141,-43.204,23.540,0.000,0.000|FS:60,0><Run|MPos:-159.147,-43.198,23.490,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.139,-43.193,23.440,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.198,23.390,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.203,23.340,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.197,23.290,0.000,0.000|FS:60,0><Run|MPos:-159.145,-43.203,23.240,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.208,23.190,0.000,0.000|FS:60,0><Run|MPos:-159.136,-43.203,23.140,0.000,0.000|FS:60,0><Run|MPos:-159.136,-43.208,23.090,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.142,-43.202,23.040,0.000,0.000|FS:60,0><Run|MPos:-159.142,-43.207,22.990,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.142,-43.212,22.940,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.217,22.890,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.201,22.840,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.206,22.790,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.211,22.740,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.218,22.680,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.212,22.630,0.000,0.000|FS:60,0><Run|MPos:-159.146,-43.217,22.580,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.137,-43.212,22.530,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.216,22.490,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.137,-43.221,22.440,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.215,22.390,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.220,22.340,0.000,0.000|FS:60,0><Run|MPos:-159.143,-43.226,22.290,0.000,0.000|FS:60,0><Run|MPos:-159.134,-43.221,22.230,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.215,22.180,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.220,22.130,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.226,22.080,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.140,-43.231,22.030,0.000,0.000|FS:60,0><Run|MPos:-159.147,-43.225,21.980,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.138,-43.220,21.930,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.224,21.890,0.000,0.000|FS:60,0><Run|MPos:-159.138,-43.229,21.840,0.000,0.000|FS:60,0><Run|MPos:-159.137,-43.234,21.790,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.228,21.740,0.000,0.000|FS:60,0><Run|MPos:-159.144,-43.233,21.690,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.228,21.640,0.000,0.000|FS:60,0><Run|MPos:-159.135,-43.233,21.590,0.000,0.000|FS:60,0|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.142,-43.227,21.540,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.232,21.490,0.000,0.000|FS:60,0|Ov:100,100,100><Run|MPos:-159.141,-43.237,21.440,0.000,0.000|FS:60,0><Run|MPos:-159.141,-43.243,21.390,0.000,0.000|FS:60,0><Run|MPos:-159.140,-43.226,21.340,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.231,21.290,0.000,0.000|FS:60,0><Run|MPos:-159.139,-43.236,21.240,0.000,0.000|FS:60,0|Pn:P><Run|MPos:-159.139,-43.237,21.230,0.000,0.000|FS:48,0|Pn:P><Run|MPos:-159.139,-43.242,21.180,0.000,0.000|FS:18,0|Pn:P><Run|MPos:-159.145,-43.236,21.130,0.000,0.000|FS:0,0|Pn:P|WCO:-41.910,305.209,21.130,0.000,0.000><Run|MPos:-159.145,-43.241,21.080,0.000,0.000|FS:0,0|Pn:P><Run|MPos:-159.137,-43.236,21.030,0.000,0.000|FS:0,0|Pn:P|Ov:100,100,100><Run|MPos:-159.136,-43.240,20.990,0.000,0.000|FS:0,0|Pn:P><Idle|MPos:-159.136,-43.241,20.980,0.000,0.000|FS:0,0|Pn:P>[MSG:DBG: Belt positions saved to NVS: TL=1944.176 TR=2217.205 BL=1900.298 BR=2172.543 state=7][PRB:-159.139,-43.237,21.230,1.616,0.000:1]$J=G90 G21 F1000 ZNaN [MSG:INFO: Probe offset applied:]okERROR:2Missing the expected G-code word value or numeric value format is not valid.
