A Place to put your little tools or items that help assemble or make using the maslow a more enjoyable experiance
Hey this is a little tool I designed to greatly aid in the assembly of the cnc, It cuts the time to assemble by a lot, and saves a great deal of fatigue in the hands. Consider helping me escape the hard labor force. Thx. venmo @James-Huson-2
I used a pick/scribe/awl to slide the nut into the hole then a punch to hold it in place while I turned the screw. Your tool seems to combine both function and most likely easier to use. Thanks for sharing.
I used the small torx screwdriver included with the maslow to pick up and position the nuts, but it sticks through enough that the screw can’t start while holding it.
