Maslow not flush with cutting surface
I set my maslow up vertically on a 4x8 and when I cut anything that’s not in the middle the whole sled starts pulling off the wall from the bottom, causing it to not cut all the way through. Do I need to apply more tension when calibrating? (I pulled the sled off with my hand for the picture)
This is generally an indication that you need more angle on your frame, like it’s a little too vertical
Thanks, its a lot smoother now
