Caveat - I haven’t tested this yet. It looks like I’ll need to remove the router to make it fit but look feasible. I also rescaled the pen holder down by 1% so as to make it a little easier to screw into the mount.
I’ve adjusted to fit:
- Sharpie Mini - https://www.amazon.ca/dp/B0845ST4SF
- Spring - https://www.amazon.ca/dp/B0C33CQ5KS
Maslow_Sharpie_holder.stl (380.5 KB)
I don’t have mini Sharpies, so I could be wrong, but it seems like the Chinese markers I use are very similar in dimensions.
To fit them under the router, I have to cut them a little shorter, about 1cm. Then, I fill the end with a bit of hot glue.
Perfect, thanks. Yeah, I’d already expected to have to shorten the Mini. I’ll try to print the mount this weekend. If post if any mods are needed
