Hello! I see in the “not shop” that I can ask you for a design of a 50mm vacuum cleaner holder. Do you have any advice for 3D printing this part?
Absolutely! Do you want 50mm on the inside or on the outside of the hole?
on the inside would be great!
Dust Hose 50mm.stl (6.0 MB)
Here you go!
I recommend printing it at 100% infill (because it’s basically just walls) and using normal supports, it should print pretty smoothly. I put the flat side down just like it will go in the machine.
Thank you! I am going to try to print it.
