I’m looking to get accurate time estimates from Fusion360 simulation. The last value I’m uncertain on and want a sanity check for is the plunge rate I should be using.
Looks like the maxZRPM in the firmware is 12.6 (RPM?). And the default zDistPerRot is 3.17 (mm?). Does that mean, with the default zaxis setup (Rigid + stock motor), the plunge rate maxes out at 39.942mm / min (~1.57in/min)? Is my math correct?
