Maximum file size? WebControl stops with KeyError Session is disconnected
Morning,
I am trying to carve a fairly complex Gcode file (15MB uncompressed) and upon uploading I get the above mention. Is this due to the file size, due to the computer that runs WebControl, or is there another possible error?
Thanks
marie.o
At loadUpdateFile
selectedGcode=./Seedoktor_1.nc
uncompressed:15366487
compressed3D:1933503
Client disconnected
Traceback (most recent call last):
File “/usr/local/lib/python3.7/dist-packages/gevent/pywsgi.py”, line 976, in handle_one_response
self.run_application()
File “/usr/local/lib/python3.7/dist-packages/gevent/pywsgi.py”, line 923, in run_application
self.result = self.application(self.environ, self.start_response)
File “/usr/local/lib/python3.7/dist-packages/flask/app.py”, line 2309, in call
return self.wsgi_app(environ, start_response)
File “/usr/local/lib/python3.7/dist-packages/flask_socketio/init.py”, line 43, in call
start_response)
File “/usr/local/lib/python3.7/dist-packages/engineio/middleware.py”, line 47, in call
return self.engineio_app.handle_request(environ, start_response)
File “/usr/local/lib/python3.7/dist-packages/socketio/server.py”, line 360, in handle_request
return self.eio.handle_request(environ, start_response)
File “/usr/local/lib/python3.7/dist-packages/engineio/server.py”, line 298, in handle_request
socket = self._get_socket(sid)
File “/usr/local/lib/python3.7/dist-packages/engineio/server.py”, line 439, in _get_socket
raise KeyError(‘Session is disconnected’)
KeyError: ‘Session is disconnected’
2020-12-24T08:19:19Z {‘REMOTE_ADDR’: ‘10.1.2.157’, ‘REMOTE_PORT’: ‘56390’, ‘HTTP_HOST’: ‘192.168.80.141:5000’, (hidden keys: 26)} failed with KeyError
{“hostAddress”: “192.168.80.141:5000”}
connected
57daba1b73004d37bd4f8ab7cbf14adc
I’m connected!
Sending Gcode compressed
Sent Gcode compressed
