Hi all. My Maslow has been sitting idle for quite some time, but I am finally back using it again. Successfully made a cut yesterday, using Webcontrol for the first time. Imported the groundcontrol.ini and everything worked perfectly.
Today…not so much. Webcontrol keeps stopping around line 50 in the gcode, unexpectedly and gives no errors. Any ideas what might be causing it? It is a relatively simple cut. Diagnostics report and gcode are attached.activity board.nc (21.0 KB) wc_diagnostics_20201128-115918.zip (201.0 KB)
I am running Webcontrol on a Windows 10 PC. I even reinstalled on a new PC since I suspected the first PC could have been the issue (CPU always 95-100%), but the new PC had the same issue as well.
Is buffering turned on? If so, try turning it off and see if it performs differently.
Also, you can put the controller in fake servo mode and run the code in a simulation. It would be good to know if it always fails at the exact same line.
In general, I recommend against buffering gcode… it was too problematic to deal with and there’s still likely some issues using it. I don’t think it makes a huge difference in speed to buffer or not.
