steden
1
๐๐ฎ๐จ ๐ค๐ 5 Pieces Collet Adapter Die Grinder Chuck Driver Adapter 1/4" to 1/8" CNC Engraving Bit Router Converter for Engraving Milling Machine Tool
HQMaster Downcut Bit 1/8" Shank Down Cut Spiral CNC Router Bits End Mill Tungsten Carbide Milling Cutter Set 5 Pack (3.175mm)
Feed Rate 1800 mm/min
Plunge Rate 400mm/min
Dano
2
Nicely done ! Great profile of the state. How do you plan to connect the UP?
Metro Detroit here.
-Dano
steden
3
Bracket.
I cut it for a family member and they specifically wanted 2 parts. I would have merged them and avoided bracket.
Iโll update with images once he finishes it.
MartinJ
4
You should make sure the bracket looks like a suspension bridge.
