Saludos, espero que alguien pueada ayudarme tengo un error con GCODE ya lei todos los post aqui pero no entiendo mucho por eso pongo este nuevo, el error es este Oops! This gcode line has caused a calculation error, it will be replaced by:.
Pongo fotos de lo que sucede cada que mando cortar, no estoy seguro cual sea el problema si los motores o el sofware que estoy usando, es makercam.com muchas gracias que tengan un exelente dia.
“Greetings, I hope someone can help me I have an error with GCODE and I read all the posts here but I do not understand much why I put this new one, the error is this Oops! This gcode line has caused a calculation error, it will be replaced by :.
I put pictures of what happens every time I cut, I’m not sure what the problem is if the engines or the software I’m using is makercam.com thank you very much for having an excellent day.”
Hello! Are you able to attach the gcode file here so that we can try to test it? It looks like in Ground Control I see the words “GALLE” but the cut parts seem to be a different shape. What should they look like?
¡Hola! ¿Puedes adjuntar aquí el archivo gcode para intentar probarlo? Parece que en Ground Control veo las palabras “GALLE” pero las partes cortadas parecen tener una forma diferente. ¿Cómo deberían verse?
Hola, gracias por responder, el GCODE antiguo ya lo perdi pero tengo otro nuevo que tambien tiene errores subo fotos y el codigo,muchas gracias por tu ayuda.
Nails 5.nc (25.2 KB)The gcode looks clean in a text editor, camotics and GC. It is way off x0,y0 though but you seemed to have managed that.
This looks like some mechanical error. Did you notice the chain jump or the rollers not running smooth on the ring?
The “N” could be a holding tab that is to close to the corner.
I don’t speak English very much but I think I understand but i am no sure, the answer is yes the chain jumb always all the files I did but I don’t know why and I moved the 0 to the lower left corner because I wanted to occupy that part exactly on a 48 “x96” sheet, thank for you help
The chain jumps if the the chain is not straight with the motor sprocket. You can search → chain guide ← here in the forum, or → maslowcnc chain guide ← you can find many options to stop the chain from jumping. Can you post some picture from your sled and the motors?
La cadena salta si la cadena no está recta con el piñón del motor. Puede buscar -> chain guide (guía de cadena) <- aquí en el foro, o -> guía de cadena maslowcnc <- puede encontrar muchas opciones para evitar que la cadena salte. ¿Puedes publicar alguna imagen de tu trineo y los motores?
Hola gracia por tu ayuda, se que hay muchas soluciones aquí en el foro ya leí muchas el problema es que no les entiendo y tengo que traducir todo y el traductor no es tan bueno en cosas técnicas por eso busco soluciones en español, también pueden ayudarme videos en. Ingles esos si los entiendo.
Thank you, I know I have very solutions in this forums I read many but the problem is I don’t understand if use the translation is no very good that’s way I search Spanish solutions, the videos help me a lot no matter the language but I don’t see it in this forum.
Es: Hola, lo siento pero apenas hablo español, esta es una traducción de Google. Creo que el error que enumeró en su primer mensaje
En: Hi, I’m sorry but I speak barely any Spanish, so this is a Google translation. I believe the error you listed in your first message
Es: es porque el programa está tratando de crear un arco con un radio muy grande. Esto causa problemas porque la computadora tiene problemas para representar números muy grandes. Entonces “Ground Control” está reemplazando el arco con una línea recta. Esto no es un problema, solo una notificación.
En: is because the program is trying to create an arc with a very large radius. This causes problems because the computer has trouble accurately representing very large numbers. So “Ground Control” is replacing the arc with a straight line. This isn’t a problem, just a notification.
Es: Los problemas que está teniendo con las esquinas redondeadas podrían deberse a la cadena de salto. También podría deberse a la adherencia del trineo, que generalmente es peor en las esquinas inferiores del área de trabajo.
En: The problems you are having with rounded corners could be due to the chain jumping. It also could be due to the sled sticking, which is usually worse in the lower corners of the work area.
Que tal, estoy seguro de que el problema es por que se brinca un diente la cadena, mira para prueba y error, pon tu maslowcnc centrado antes de cortar, puede usar una hoja ya usada solo vas a probar margen y error, antes de empezar la prueba, coloca tu maslowncnc en el centro y marca con la broca el centro, vamos pues haz un agujero en el centro del diámetro solo de la broca, baja el eje Z unos 3mm para que se marque, después empieza la prueba con unos de los codigos G que ya te dieron el error, aunque la maquina o router este apagado corre el código en gcountrol como si estuvieras cortando, cuando acabe de cortar por así decirlo o realizar todos los traslados el router vuelve al centro y ahora si vuelve a marcar el centro con el router encendido baja el eje Z 3mm, ahora si, mira si el centro o marca de la broca queda en el mismo lugar que al inicio, si no es asi, es por que se esta brincando un diente alguna de la cadena o las dos, a mi me paso eso, revisa eso primero y si no quedan las marcas en el mismo lugar, tendras que volver a calibrar por que de tantos cortes ya no tienes el mismo centro, yo por suerte me di cuenta pronto y lo solucione sin calibrar, ya que si batalle mucho en calibrarlo. Saludos!
How about, I’m sure the problem is because you jump a chain tooth, look for trial and error, put your maslowcnc centered before cutting, you can use a sheet already used just going to try margin and error, before you start the test, place your maslowncnc in the center and mark the center with the bit, then drill a hole in the center of the diameter only of the bit, lower the Z axis about 3mm to mark, then start the test with some of the G codes that already gave you the error, even if the machine or router is turned off runs the code in gcountrol as if you were cutting, when you finish cutting as it were or make all the transfers the router returns to the center and now if you redial the center with the router on lowers the Z axis 3mm, now yes, see if the center or mark of the drill is in the same place as at the beginning, if not, it is because it is jumping a tooth some of the chain or both, to me that happened, check that first and if not an the marks in the same place, you will have to re-calibrate because of so many cuts you no longer have the same center, I luckily I realized soon and solve without calibrating, because if you struggle a lot to calibrate it. Regards!
Si tienes razón a mi también me costo mucho calibrar, Muchas gracias por su ayuda voy a intentar eso descargue unos archivos para una impresora 3D que creo que evitan los brincos espero que esto funcione.
¡Buena suerte!
